Parking light wire and Dome light/ courtesy door light wire location for trigger wires?
n1comedes
San Diego
Toyota 4Runner
Was able to install the Diode Dynamics D Switch Panel, Baja Designs rock lights and Diode Dynamics C2 2.0 chase lights. First time ever working on electrical and it works!🄳 Does anyone know where I can tap the trigger wires (specifically the parking light wire and the dome light/ courtesy door lights wire) and what color wires they are? Thank you in advance.
courtesy light switches for front doors go to main body ecu 18 green or 19 violet
2025 2026 4runner 6th gen Parking light wire and Dome light/ courtesy door light wire location for trigger wires? 1781459026010-s1
rocktheroad
Tampa
4Runner TRD ORP
Are you referring to the driver side behind the aux switches?
Did you had any progress on this? I just got mine D-Switch, and I was trying to figure out this too….
Here is what I found, and keeps me puzzled:
D-Switch sensor wires need a simple +12V signal, not CAN/LIN/message-based signals. The D-Switch guide says the accessory harness sensor wires require 12VDC discrete signals and will not work with CAN, LIN, CXPI, or other message-based protocols.
n1comedes
San Diego
Toyota 4Runner
rocktheroad
Tampa
4Runner TRD ORP
We are in the same boat :)
I even managed to break the closing lid of the D-Switch right after I opened the package. So, I’ll wait until someone figures it out. I’ll post here if I find any other information!
