SXTH Element
2024 Tundra TRD Off Road, 2024 Tacoma TRD Off Road
New product alert:
Over here at SXTH Element, we’ve been developing a high-clearance Trail Pipe for the new 4Runner and Land Cruiser. This setup is designed to improve clearance, clean up the factory exhaust layout, and hold up to real trail use.
What It Does:
  • Deletes the OEM rear resonator
  • Improves ground clearance by tucking the exhaust up higher
  • Follows the factory exhaust path and bolts to the OEM muffler
  • Slight sound increase (~8–12 dB, still very livable in the cabin)
Build Details:
  • 304 stainless steel construction
  • CNC-bent tubing
  • TIG welded throughout
  • Brushed finish for durability
This is a simple, functional upgrade. Less about making noise, more about getting that low-hanging section out of the way when you're off-road.
Preorders are officially open now. If you're planning to get your 4Runner or Land Cruiser out on the trails, this is one of those small changes that makes a big difference.
👉 Preorder / Full Details:
https://sxthelement.com/products/toyota-4runner-land-cruiser-trail-pipe-2024?variant=51048513143082
Next batch is expected soon, so if you're interested, now’s the time to get in line.
If you’ve got questions about fitment, install, or how it compares to the Tacoma version, feel free to ask.
2025 2026 4runner 6th gen [Vendor Post] Trail Pipe for 2025-2026 4Runner / 2024+ Land Cruiser by SXTH Element – Now Available for Preorder Render5
Climbandroll
Va
How much ground clearance was gained in your tests, and what were the trims/specs of the trucks that it was tested on (e.g., TRD OR on factory wheels, tires, suspension)?
jspec_rnr
Jeff
Alabama
2025 4Runner TRD ORP
I preordered this, I hate how the stock exhaust hangs and it need a little more sound.
js_panda_rnr
Installed my trail pipe this morning. Love the improved clearance and clean look of the rear now.
2025 2026 4runner 6th gen [Vendor Post] Trail Pipe for 2025-2026 4Runner / 2024+ Land Cruiser by SXTH Element – Now Available for Preorder PXL_20260604_164633126
2025 2026 4runner 6th gen [Vendor Post] Trail Pipe for 2025-2026 4Runner / 2024+ Land Cruiser by SXTH Element – Now Available for Preorder PXL_20260604_164646728
js_panda_rnr
How was the sound? Notice a difference?
The most noticeable difference is at cold start. It's def louder than before but not obnoxious by any means. Once the idle settles it's barely different from stock. Under acceleration, from in the cabin, it's sliiiightly louder and the overall tone has a deeper, throat-y quality (sorry, couldn't think of a better description). I took a drive for errands a little while ago and didn't experience anything I'd consider "drone."
