gvan1998
MD
ToYoDaMan
Allan
Bay Area
I looked at that but prefer the powder coated aluminum over plastic.
Thanks for the link. I did look at the install manual and looks simple enough.
From what you know during your install, does the three bolts point of connections currently serve any purpose? Or are they just there for accessory upgrades like this cover?
thanks for any insights. It looks so much better.
Mike N
Rochester, NY
I think three bolts for mounting the cover brackets were securing other mounts but adding the brackets did not impact anything. The fourth one is added to an existing empty mounting hole. I installed it a while ago so going on memory. It was an easy install. Let comes with everything including easy to follow instructions. I'm pretty sure they have a video on YouTube.
morsk
NY
2026 SR5
Front tint overlays on the orange side markers and painted rear tow hook
Where did you get that classic tri-color badge on your front grill? Or did that come with the truck?
croome21
Cal
2025 Toyota 4runner SR5
Installed ditch lights and switch. Took me all afternoon to do the wiring - watched several tutorials on YouTube and got it all to work!
2025 2026 4runner 6th gen What did you do to your 6th Gen 4Runner today?? 👨🏻‍🔧 🧰 🛠 IMG_2213
2025 2026 4runner 6th gen What did you do to your 6th Gen 4Runner today?? 👨🏻‍🔧 🧰 🛠 IMG_2214
Jerry
2025 TRD Off Road Premium, 2015 Lexus ES 350
Looks good!!! That’s one of the next things on the list. Did you tap into another wire so the button stays illuminated when it gets dark? If so which wire???
jayT
john
Louisiana
armor installed yesterday
really nice rig set-up!!!! what size tires are you running? i'm thinking about switching from 285 70 R17 to 255 80 R17..thanks
croome21
Cal
Thanks! I didn’t tap into another wire… I’m guessing it draws some power directly from the battery connection to stay illuminated 🤷🏻‍♂️
mfoga
r4unner
If you followed the instructions the backlight for switch is paired with power so it’s always on. someone said pink wire is illumination wire on factory switches.
