clarkdot7
Las Vegas
2025 4runner sr5
ARB OME MT64 Suspension Lift Kit (2.5 inches front / 2 inches rear) on 2025 4runner SR5
Finally got around to installing the MT64 lift on the car. A whole day install ordeal but very worth it in the end.
2025 2026 4runner 6th gen ARB OME MT64 Suspension Lift Kit (2.5 inches front / 2 inches rear) on 2025 4runner SR5 34766-1ed6694e5149365dd8cf830a4e4ec
2025 2026 4runner 6th gen ARB OME MT64 Suspension Lift Kit (2.5 inches front / 2 inches rear) on 2025 4runner SR5 34764-1aba8ac2746e4316b5155323ed7b1710
2025 2026 4runner 6th gen ARB OME MT64 Suspension Lift Kit (2.5 inches front / 2 inches rear) on 2025 4runner SR5 34765-a4cadeea39259c670b053343217e54ad
Congrats!
Did you do the # 2135K kit (with the UCA) or the one without? Did you buy direct from ARB?
Sounds like you did it yourself. (right?) I am contemplating that and wondering how tough the UCA is to remove and replace.
Any photos or videos of the install itself?
What were the toughest/trickiest parts?
Advice on any lessons learned after working through those tricky spots?
Key references for guiding the install? (I've watched ARBs video and a few others but hearing from another DYIer is always helpful - and you may have found something I've missed as a guide.)
Looking forward to hearing how it performs off road.
Congrats again.
suremang
Bay Area
25 4Runner TRD ORP
Congrats!
Congrats again.
I installed the OME MT64 myself with the help of friends and by far the most difficult part was loosening the stock UCA bolt. It is torqued on there pretty good so definitely use a breaker bar and/or cheater bar to break it loose. Just remember to put load on the suspension before you torque down the UCA bolt. Full suspension install can be done by yourself but goes much smoother with another person or two. Otherwise the install is pretty straight forward.
clarkdot7
Las Vegas
2025 4runner sr5
Left mine at 3" so we can add the winch soon, without the extra work.
yours does look good too!
Questions for the UCA where do the brackets it comes with actually go? That was the only thing we didn’t install because we couldn’t figure it out
