All New Fox 2.5 Performance series Coilovers & Rear Shocks Installed on 6th Gen 4runner- Disappointing
porkyfly
Mid atlantic
2025 4runner TRD Offroad
yes it absolutely could and I do have a fox wrench to adjust the preload collar. Really didn’t want to lose the front height though.
I may try it however.
it's also possible that your new rear springs are stiffer than stock if you installed https://toyteclifts.com/rcc2-0-p-to...ls-fj-03-4runner-03-gx?find=2025-4runner-1625
> "10% increase in load capacity/spring rate."
If I had to guess I'd say the firmer ride may have been due to
- stiffer rear springs
- maxed out preload on the front coilovers
- E load tires
rather than the shock valving itself, but it could still be very possible that the Fox 2.5 front coilovers have worse ride quality than the Fox 2.0
AZGOLD
AH
Prescott
2025 ORP 4runner
I have OME 3344`s on the way. Hopefully that will solve the creaking, and the stiffer rear.
Heres a new plan for the coilovers:
I have a 1/4" steel spacer that I could install that should give me 1/2" lift to make up for me lowering the preload 1/4" so I dont lose any height. This wont affect the preload, so theoretically the ride should absolutely get better..
Then another re-alignment.
In hindsight , I should have just gone with the OME lift kit, and I wouldnt be dealing with any on of this nonsense today. The OME kit would have cost less at this point.
