Cranberry
Manitoba Canada
Not much to report on my install here but i saw a few people were asking about radio set ups in other posts. Iv ran CB for the last 20 years and as of this year for the first time ditched CB totally and have gone full GMRS. in the last 7 years i think i was able to talk to 3 - 4 people on CB when just channel hopping and board. within the last month alone on GMRS i have had conversations with 5 or 6 people already ranging from construction workers board to regular people walking their dog. Sometimes i get lucky and even pick up hotel room chatter that can be very entertaining. I find it fun to pass time on drives to just scan channels and listen and sometimes jump in on a conversation.
My buddy and I both made the jump together and went with the identical radios. I run the stubby 3db 4" antenna 24/7 but keep a 3 foot 6db antenna in the rear storage incase im hitting any serious rides that require the distance for talk.
I ran the antenna through the firewall near the drivers side, zip tied it along the firewall in the engine bay and mounted the NMO antenna mount near the passenger side hood.
In the cab i ran the antenna line under the driver side dash up to the centre consol, then hid the line up under the plastics in the centre console along to the back of the centre consol beside the drivers seat. I looped the antenna cable down and under the drivers seat and mounted the radio base station directly under the drivers seat. It fits perfect with about 3/4 of an inch of space above it so the seat can move freely without pinching or crimping the radio.
I tied the radio into the factory AUX connector with AUX button 2, the install was very simple, took less then an hour to run everything and mount it with zip ties.
On testing i can compare to my CB set up vs my new GMRS set up, the results clearly show the better option.
CB RESULTS (4 foot antenna)
Dense City / Urban Buildings Talk - 1 KM talk distance
Highway Open Talk - 2 - 4 KM talk distance
Forest / Valleys - 1 - 2 km talk distance
GMRS RESULTS (50 watt radio with 6db 3 foot antenna)
Dense City / Urban Buildings Talk - 6 - 8KM talk distance
Highway Open Talk - 30 - 40 KM talk distance
Forest / Valleys - not tested yet
2025 2026 4runner 6th gen Midland MXT575 GMRS Two Way Radio 50 Watt - Hidden Install 32346-162600ec9df9f54444ee581c1dbb25
2025 2026 4runner 6th gen Midland MXT575 GMRS Two Way Radio 50 Watt - Hidden Install 32347-58cc1b1ffeab74046dbdb5127ece1ad1
2025 2026 4runner 6th gen Midland MXT575 GMRS Two Way Radio 50 Watt - Hidden Install 32348-8823721310a0557a2e48be4da0e2fff9
kzrman
Maine
2025 Trailhunter
https://www.4runner6g.com/forum/threads/has-anyone-wired-a-ham-radio-yet.5046/#post-118350
Beedeviled
Stacey
2026 4Runner Limited
This is clean setup. Like it! Always thought about adding a radio but never have. Is it easy to jump in or is there a learning curve for radio comms lingo?
Cranberry
Cranberry
Manitoba Canada
Very easy unless your going HAM. I found when doing my HAM there was a lot of learning curve and after finally getting it down i found there was not much to talk to out there unless hitting repeaters.
GMRS in my opinion is as simple as it can get. Its almost as simple as CB.
If you like listening to radio chatter or want to be able to hand off a hand held to a friend in another vehicle, it doesn't get much easier then GMRS
Beedeviled
Stacey
Ok. Dig it!
kzrman
Maine
2025 Trailhunter
Please keep in mind that GMRS requires a FCC license. FRS does not.
Unlike becoming a HAM however you don't half to take a test, you just pay a fee.
shine
Seattle
HAM enthusiast here... GMRS is definitely the way to go if you want to listen to/chat with random people. Also easier to get your buddies on GMRS when you want to talk while on the trail.
That said, on every trail run that I've been on there have been others on whatever GMRS channel we were using. GMRS has more users and fewer frequency options, meaning you're more likely to hear others or be picked up by others.
quadna71
Delaware
2025 4runner
In the US, yes. Not sure if that is the case in Canada. I have had my license for a couple years now but haven't installed a radio yet in my 4Runner. Have to say that this post is really pushing me to take that step.
We started with FRS radios that were helpful for parking our camper (I drove the truck while she helped guide me into the spot) and escalated to GMRS occasionally at work (10 story building) to also while driving two vehicles on road trips. I imagine having a 50w option in the 4Runner would be awesome! I think I envisioned it being mounted on the dash more than down low, but in reality haven't really looked into permanent mounting options.
KD2MYW
Phil
NYC
Hello! Thanks for sharing this. I actually have my ham and GMRS licenses but still contemplating CB. Your install looks real slick. How hard was it to fish the antenna with the pl259 through the firewall?
Cranberry
Cranberry
Manitoba Canada
It was easy. I took a metal coat hanger and tapped the antenna to it. Put some soap on the cable so it slides easy through the rubber grommets in the fire wall.
Poke the hanger through the grommet then pull the rest of it through.
Took me less then an hour to run everything and mount it.
Good luck and enjoy the radio chatter!
KD2MYW
Phil
NYC
Is this where you came through the firewall?
Thanks!
2025 2026 4runner 6th gen Midland MXT575 GMRS Two Way Radio 50 Watt - Hidden Install IMG_1285
Cranberry
Cranberry
Manitoba Canada
KD2MYW
Phil
NYC
I hate to ask another question but where do you grab power?
Cranberry
Cranberry
Manitoba Canada
I toed into AUX 3 wire inside the cabin. The manual outlines what wire it is.
Do you have factory AUX buttons? If not then you need to splice into a fused line or run a whole new 12v line
