OEM TRD Performance Cold Air Intake CAI fitment
Scrappopatamus
Barry
Midway KY
You're going to need to take It to the dealer and have them upload the file, if not it's going to throw a code. Mass Air Flow Sensor is located in differing location from what I've been told
Josalbrec6G
joe
cincy
2025 4Runner 6G
So how did it workout? Any noticeable gains in mpg or power? Any adverse effects? Is the intake louder?
I received the TRD intake currently used on the TRD PRO and tried to install. I purchased the housing, filter and end caps. The intake hose that connects the engine is 1.25” off-set than the needed TRD pro hose and I was not able to install. I ordered the one from Toyota and it has since been discontinued. I am stuck with an intake I can’t use at all.
2025 2026 4runner 6th gen OEM TRD Performance Cold Air Intake CAI fitment IMG_2683
BonRunner
2026 TRD Sport Premium / WCP
Should just get SXTH intake for less headache 😂
Scrappopatamus
Barry
Midway KY
I would log onto the Banks Site and check out theirs. Read the description and watch the video
Josalbrec6G
joe
cincy
2025 4Runner 6G
I plan to just keep the Oem flat filter. After spending 400 on a filter I can’t use and the dealership refuses to return, I’m a little done with it.
Scrappopatamus
Barry
Midway KY
Completely Understandable. They should be able to return it to TMMA unless you've lost items or destroyed the packaging, especially considering Toyota can't supply the complete assembly. Call your sales person and put them to work. Hopefully pressure from the sales department will yield results. Good luck
ToyoTech808
Honolulu
25 4runner
Exactly what part numbers did you order? I searched up all the part numbers that make up the TRD Pro intake and they show in stock online.
Josalbrec6G
joe
cincy
2025 4Runner 6G
The intake assembly is available, the hose to connect it is not
Josalbrec6G
joe
cincy
2025 4Runner 6G
Also got the part number of the trail hunter intake air tube which is black color vs red on the pro. Idk why its more expensive also.
Let me know how it goes.
Send me that part# and I can compare to what I have. The part# I have looks to be discontinued
Josalbrec6G
joe
cincy
2025 4Runner 6G
I thought you said you ordered the pro tube number I posted?
I did order that intake hose. The issue is three dealerships have indicated this assembly and hose are being discontinued and the TRD Pro and Trailhunter will move to the flat filter. If the one I ordered is cancelled I want to order the other item
