Scangauge / Ultragauge Compatibility?
alldogsoffroad
Chad
Lincoln, NE
2025 Toyota 4Runner SR5
Hey guys! Are any of you using a scangauge 3, ultragauge, or similar? I would like to keep an eye on a numerical value for transmission temps. I know this is possible in previous gens but have not seen any info on the 6th gen. The scangauge website is not great at listing application compatibility.
Joe Dirt
I also have been looking for a good scan gauge. My previous experience has been using an OBD2 Bluetooth and have tried a few apps.
Only to be disappointed as I could never find a transmission temperature and they were paid subscription so I quickly disengaged and canceled.
I have asked this before in a previous post if anyone is using an OBD2 Bluetooth Scanner with app to collectively get transmission temperatures.
Some of them are very expensive and not really worth it because they are just cheap plastic Global Market units. And the apps aren't guaranteed to pull the right data nor is the OBD2 connector guaranteed to get into your system properly.
Hope this all makes sense but I pretty much gave up and resorted to a thermal infrared temperature gun. Those are not the most accurate but they will get you really close.
ToYoDaMan
Allan
Bay Area
I have 2 Scangauge II , Daisy chained in my 2013 Toyota Prius.
At around. 260k miles, my check engine light came on. 2 codes from the scangauge II lead to the MAF Mass Air Flow Sensor.
I went to my local O'Reilly store and picked up a MAF air flow sensor cleaner. I cleared the codes. Engine light is off after driven for hundreds of miles. All good now.
Scangauge II saved me hundreds of dollars.
It's worth the investment. I will probably purchase for my Runner when it has aged a bit. This Runner has obviously more Tech than my aging Prius.
It's beneficial to program x-gauges and monitor conditions that the vehicle does not otherwise provide.
Sample:
2025 2026 4runner 6th gen Scangauge / Ultragauge Compatibility? IMG_9676
2025 2026 4runner 6th gen Scangauge / Ultragauge Compatibility? IMG_9677
You will not be disappointed. Very reliable equipment. I've had mine on for at least 10 years and no issues.
For anyone in doubt, I hope this helps.
