So looking at pictures of the prototype interiors, the 4Runner definitely will not be able to install the compressor as an accessory. For the Tacoma there is a DC/USB power supply in the slot the air compressor occupies on non-trailhunter trims. The 4Runner has a specifically designed interior for it. One could probably make it happen with enough work, but it would not be a small task.
Here is the trailhunter and limited rear cargo areas:
I know this is a really old post I'm quoting but wanted to reference these photos when posting the ones I took of my ORP. I really like the idea of having the air compressor integrated - and I hate that I appear to have an empty spot where it could go but cannot find any details about the part. Photos below show the storage area/hybrid battery vent on my ORP. There appears to be a white connector where the compressor assembly would plug in - and there seems to be space for the compressor behind the hybrid vent pipe.
2025 2026 4runner 6th gen Onboard Air Compressor in Trailhunter 4Runner -- Specs? ARB Air Compressor? 20250730_200506
2025 2026 4runner 6th gen Onboard Air Compressor in Trailhunter 4Runner -- Specs? ARB Air Compressor? 20250731_194620
2025 2026 4runner 6th gen Onboard Air Compressor in Trailhunter 4Runner -- Specs? ARB Air Compressor? 20250731_194958
2025 2026 4runner 6th gen Onboard Air Compressor in Trailhunter 4Runner -- Specs? ARB Air Compressor? 20250731_195013
The photos from Nodak and write-up from Spike here are also helpful:
Subwoofer on different cargo area sides in different trims?
I trust the part numbers that Spike references above, and can find dealers who will sell it (online), but cannot find any details about installation: WILL I need to (carefully) cut a hole in the plastic? Does the kit come with template for the hole, hardware and trim pieces to make it match trailhunter installation? Can anyone find the installation instructions?
Thanks for any help that can be provided. I'm not inclined to spend the $$ until I know what I'll be getting.
Marc
Maryland
2025 TRD ORP
Any luck???
Marc
Maryland
2025 TRD ORP
Nope. But you MUST also be tracking this other thread where I'm trying another tack - asking the company that makes the compressor. See my last thread there. Will try to remember to update if NSV gets back to me. integrated compressor install
And someday someone is going to figure this out. My bet is on Corey who started this related thr: TH compressor part#
thanks....yes, I am tracking and I also stumbled across the Tacoma discussion. I definitely have a blank space in the back in my TRD ORP....I have also talked to my Toyota dealer about this and they are doing research too. These are the part numbers listed in the tacoma thread:
  • PT949-89240-AB
  • PT949-35240-AC
  • PT949-35240-AD
Cory39744
Cory
Virginia, USA
After months of research, these are the 2 Part #s that I am 99% certain are what we need.
PT949-89240-AB
PT949-89241
Thanks Corey - I think you are right. If only I could find an official Toyota installation guide to go with these PNs.
4RUNH Obtrifr Kit - Toyota (PT949-89241) - MSRP $1475 (on line at <$1200)
4RUN Compressor On B - Toyota (PT949-89240-AB) - MSRP $697.10 (on line at <<$500)
So do you think the first one is the actual compressor (with hoses?) and the second is the control panel and trim??
I'm still planning to go down this path but in the near term am looking forward to receiving my prize for the Wolfbox "mud" competition: jumpstarter tire inflator. It looks to have decent flow rate (1.6 cf/min) so hope its a reasonable temporary replacement for the integrated compressor I will get at some point. (I bought a portable Slime inflator for my last offroad excursion that had similar flow rate and worked fine on 3 tires and then failed completely so it got returned)
Looking forward to hearing about a successful installation into TRD OR of the TH inflator!
Thanks again.
gydooya
Eddie
Dallas
6gen TRD ORP
Reviving this thread. Has anyone been able to get the part number for the 4Runner Trailhunter onboard air compressor yet? I popped the top cap off the wheel well of my Pro yesterday and it has the power connector for it. It seems pretty plug and place other than cutting out the spot in the plastic to fit the display and bezel.
I got the answer! If you want everything included the trim panel you need to order PT949-89241-AA and if you buy it from Nucar Toyota it’s 875.00 including shipping
gydooya
Eddie
Dallas
6gen TRD ORP
Thanks again.
Did you do it? And you are correct, If you want everything included the trim panel you need to order PT949-89241-AA and if you buy it from Nucar Toyota it’s 875.00 including shipping.
I've not done it yet and am still just a bit confused - Does PT949-89241-AA include everything that is needed?: compressor, trim plate, hoses? Or is that just the trim plate for 875 and still need PT949-89240-AB or something else? And did you find an installation guide?
I'm hopeful that youve got this figured out and will soon be posting your installation results so we all (or at least Corey and me) can cheer!
gydooya
Eddie
Dallas
6gen TRD ORP
It’s includes everything! I had to reorder it from a different Toyota part company since Nucar said it was discontinued. I called my local dealership parts department and confirmed it was not discontinued. I just reordered it from here
2025 2026 4runner 6th gen Onboard Air Compressor in Trailhunter 4Runner -- Specs? ARB Air Compressor? IMG_0399
Cool! I look forward to hearing of your success in installing! Hope it arrives quickly.
gydooya
Eddie
Dallas
6gen TRD ORP
Well I just got my order and PT949-89241-AA is just the front control module not everything like I was told. I now need to buy the compressor FML
Maximus4R
Adam
Nashville
Noooooooooooooooo
gydooya
Eddie
Dallas
6gen TRD ORP
Noooooooooooooooo
It's ridiculous! I just ordered the compressor, for $500 including tax. So lets see what happens next because I think I need to order the trim panel too.
Maximus4R
Adam
Nashville
2025 2026 4runner 6th gen Onboard Air Compressor in Trailhunter 4Runner -- Specs? ARB Air Compressor? thor-marvel
