Interesting data - you’ve certainly put some effort into your research. I understand your concern with 2 ply tires - particularly off road. I am curious what your concerns are with E load tires.I just updated my tire comparison chart. Admittedly, this is designed around what specs and brands I am personally looking for, but if this helps any of you feel free to check it out. Compares 285/70 R17, 285/75 R17, 35 x 12.5 R17 and 35 x 11.5 R17.
The ground clearance column is intended to show improved ground clearance over OEM TRD PRO setup. The +/- weigh is compared to my current setup with is an OEM sized KO3 on the OEM TRD PRO rim. I redbox E loads and 2 ply sidewall construction as I typically try to avoid them.
