Van Solo
Van
Calgary / Canada
Hey Van thanks for your question and points. I’ll try my best to tackle them point by point.
1. The width will be reduced by half an inch and height increased by 2 inches. The real problem I might have is in the increase in scrub radius. But in terms of safety, these tires will provide better load bearing capacity than OEM falkens.
The pizza cutters are known to have better performance in snow than their wider counterparts.
2. Speedometer isn’t much of an issue, something that we will learn to adapt too
3. Narrower tires with lower psi actually offer more grip. And going through the snow in MB I think I will gain an edge. Not lose it
4. As for aesthetics, I don’t mind it at all
5. As for potential for increased wear, I’ve “offset” that as best as I could with the +30mm offset while increasing 2” in height. The narrow tires will mean I will be doing less wheel well modifications to fit 34.5” tires
Alright then Brother you got it sorted,
Haruharu
Garth
Winnipeg
4Runner TRD ORP
Installed the tires and rims, slight rub on mudguards. Getting alignment tomorrow.
Running 255/85/17 Mickey Thompson Baja Boss R/T
34.5” x 9.9”
Only had to trim mud flaps to fit. Caster 3.1 degrees
2025 4runner 6th gen TRD ORP Heritage Blue - 35s MT Baja Boss A/T 255/85/R17 Pizza Cutter Build +30mm Offset - Matte PPF - Aftermarket Grille Pizza cutter Baja Boss tires 255:85:17 - 34.5” x 9.9”
2025 4runner 6th gen TRD ORP Heritage Blue - 35s MT Baja Boss A/T 255/85/R17 Pizza Cutter Build +30mm Offset - Matte PPF - Aftermarket Grille Pizza cutter Baja Boss tires 255:85:17 - 34.5” x 9.9” on 2025 4runner trd orp off-road 6th gen
2025 4runner 6th gen TRD ORP Heritage Blue - 35s MT Baja Boss A/T 255/85/R17 Pizza Cutter Build +30mm Offset - Matte PPF - Aftermarket Grille Mickey Thompson Baja Boss R:T Pizza cutter tires 255:85:17 - 34.5” x 9.9”
Twomstone
Connor
Manitoba - Canada
NA
34.5” x 9.9”
Pizza cutter Baja Boss tires 255:85:17 - 34.5” x 9.9”.webp
Pizza cutter Baja Boss tires 255:85:17 - 34.5” x 9.9” on 2025 4runner trd orp off-road 6th gen.jpeg
Pizza cutter Baja Boss tires 255:85:17 - 34.5” x 9.9” on 2025 4runner trd orp.jpeg
Mickey Thompson Baja Boss R:T Pizza cutter tires 255:85:17 - 34.5” x 9.9”.webp
Looks awesome! I'm also in Winnipeg (Blue ORP). I asked about some tire details in another post but curious if the no rubbing (small trim to rear) was with your lift you have now or before?
Haruharu
Garth
Winnipeg
4Runner TRD ORP
lovely! I think I’ve seen you on the roads or my wife has at least. Seems there’s a few of us.
I got rubbing, on the flaps only, even with the lift. Without the lift would have been the same. As I understand, rubbing has more to do with offset and tire dimensions than it has to do with lift. Hope this helps
204runner
Manitoba
2025 4Runner TRD ORP
Sick build man! I'm also from Winnipeg with a 6th gen trd orp blue. It's all stock right now and it handled pretty well from yesterday's storm. I wonder how did the baja boss' handle? Looking to upgrade in the future.
Haruharu
Garth
Winnipeg
4Runner TRD ORP
Terrific, drove down the perimetere in crosswinds and it was fine. We've also been ice fishing on it with 2 feet of snow and its been great. I will say if your priority is winter grip, there are definitely better options in the Nokian Hakkapellitas LT3s!
