Rigid Switchback on Trailhunter - adjusting aim, and SwitchPros
bobholthaus
Bob
St. Louis MO
Jeep JL-370 AEV Diesel
Hello: I actually have 2 questions:
1. How do I raise these lights, meaning adjust them higher?
2. I'm going to install a SwitchPros switching system. Does anyone know if I can unhook these from the OEM wire harness, and buy the OEM pigtail to wire them to my SwitchPros so that I can switch them using that system?
Thanks in advance.
Bob Holthaus in St. Louis, MO
Sleepy808
Hawaii
2025 Underground Pro
Thanks in advance.
I have a TRD pro and recently switched out my OEM rigid fogs for rigid amber pros. The OEM connecter uses a canbus or something proprietary…definitely not simple for a layperson like myself. So I dont know if you can simply wire it up. I ended up using one of the OEM aux connectors to make my new fogs functional.
bobholthaus
bobholthaus
Bob
St. Louis MO
Is there any adjustment screwed to aim them higher that you are aware of?
Sleepy808
Hawaii
I got the adapter kit from Rigid and when thats installed, the lights are pretty flush to the bumper cutout. I wqs able to push it up and down ever so slightly when i out the bumper back on, but it wasnt a significant amount. Really only gave me a mm or two of adjustment.
bobholthaus
bobholthaus
Bob
St. Louis MO
So I jammed some rubber spacers between the bottom of the light and the top of the opening that had sticky stuff on them and were about 1/4" thick and it helped. I need them to be slightly thicker even. Not sure I'm going to get more, but every millimeter helps when aiming lights!
bobholthaus
bobholthaus
Bob
St. Louis MO
They're were round circles of rubber that came with a piece of stereo hardware (that's my business). I cut them in half and wedged them in. I'll take a pic today.
