Removing resonator or replacing muffler
chrismacc
chris
dallas, Ga
Has anyone just removed the resonator? Looking for a little more sound from the exhaust and I figure that would be a good start. Or perhaps weld in a viral muffler or something? Thanks
2025 2026 4runner 6th gen Removing resonator or replacing muffler IMG_4087
ExploreMore
US
25 4Runner TRD Pro
Chris send me a PM. Maybe we could do a swap if you're close to me. I have a 25 TRD Pro, they have no resonator.
but that doesnt eliminate the muffler, that is after the muffler
Van Solo
Van
Calgary / Canada
I have it removed and replaced with a straight pipe. (Resonator)
Mainly due to off road use.
As for the muffler, we will be replacing at some point to introduce a less restrictive solution.
chrismacc
chrismacc
chris
dallas, Ga
Which muffler you going to go with?
mcd_ovrlnd
SE PA
2025 4Runner TRD PRO
I installed the Nytop exhaust dump. TRD PRO has no resonator, but I was just trying to create more clearance in the back. But I believe they said you can install this on other models and it deletes the resonator. It’s expensive though. Biggest downside.
3rdRunner
Bill
SXTH has the Trail Pipe. Basically an axle dump. You lose the resonator but keep the factory muffler. Great clearance and a subtle increase in sound. I use this. Tried the OFG Cat Back from AWE but if couldn’t handle low rpm/high gear scenarios - produced an overwhelming resonance.
mcd_ovrlnd
SE PA
I’d love to hear the SXTH. I feel like the Nytop gives more growl and sometimes hear that low rpm/high gear you mention. But can’t tell for myself if it’s worse than the oem pipe.
Van Solo
Van
Calgary / Canada
yes we did, just a mild sound increase.
