Rear Reflector Replacement
honeymauney
Lauren
Cullowhee, NC USA
2025 Toyota 4Runner SR5
Hi! I want to know if anyone has had success replacing back bumper reflectors.
I want to replace the factory reflectors with plug and play brake light accessories. Seller did not provide installation instructions, and after looking underneath the car, I have a feeling I will need a few hours to tear down the bumper completely in order to do this install. The reflectors are screwed in rather than secured by a pin. Has anyone else found a way to do it faster?
2025 2026 4runner 6th gen Rear Reflector Replacement IMG_0613
2025 2026 4runner 6th gen Rear Reflector Replacement IMG_0614
Vander
G
SC
2026 Toyota TRD Sport Premium
I purchased some similar ones from Amazon. They came with a plastic pry tool. The instructions said the reflectors pry out. I tried to pry one edge and broke the reflector. That ended the installed for me. I also see foam pieces in the bumper. Don't know what they are for, but I guess the foam would need to be removed to mount the lights. If you find any info on the install, please share. I would like to install them.
RunnerRocks
RedDog
Nature
2026 TRD ORP (non-hybrid)
Are the lights also reflectors ?
honeymauney
honeymauney
Lauren
Cullowhee, NC USA
how to make your parked vehicle even more invisible at night for 100, Alex
I live in rural NC, about 2 miles off of any main road and on the peak of a mountain. So no one is coming near my parked vehicle at night :) You're hilarious though!
Rotorjock
Sven
Iowa
2026 Toyota 4Runner
I installed light to replace the reflector. It was not as simple as you would be led to believe. There is a screw accessed from behind each reflector. I had to take some trim pieces off the rear wheel wells to get to the back of the bumper and the screw on the reflector. I didn't have to remove any foam. There was a tricky bumper clip on the back of the bumper that i used a pinching tool from by fishing tackle box to uninstall and reinstall. https://parts.capovalleytoyota.com/...ZE5DPkJ6jrXxDT0WFXNsVpBGasabe4dOOy1fMQPcxr7td
It took me about an hour.
Vander
G
SC
Rotorjack, Thanks for the info. I haven’t tried to install mine yet.
New4RunnerSR5
Ben
Philly
2025 SR5
Looking to install these as well. Where does it tie in to the taillights? Mine came with the attached wiring harness.
2025 2026 4runner 6th gen Rear Reflector Replacement 17900005607916660048269176071628
New4RunnerSR5
Ben
Philly
2025 SR5
Got it done. Took the whole bumper off. You could probably do it without that, theres a silver phillips head screw in the back of each reflector, if you could get those out and back in, you could do it. My big dumb hands couldnt get them though. Each light wires into that sides taillight, very easy once i figured out they were meant to be two separate pieces. Maybe 2.5 hours with clean up.
