OTT tune results (from TRDJon)
JustDSM
Justin
Ogden, UT
2024 Tacoma TRD Offroad
Not exactly true, for a couple of reasons. The warranty can't be 'voided' for modification. They would need to have reasonable proof that the modification caused a failure. This applies to larger tires, lifts, intakes, or really anything aftermarket.
The other reason, is that the Accessport can be uninstalled in minutes for service appointments, and leaves no trace.
these new Denso ECU's are not what you are used to. I have a customer who is a service manager at Toyota, and he made every effort to detect that the ECU had ever been flashed or had an other than stock file on it after he uninstalled his Accessport for a recall on his truck. There was no trace.
Can confirm!
Rock Doc
Joshua
Alexandria
2025 TRD Pro and 2002 Tundra
What’s your favorite part about the tune?
Living in the DMV traffic is a bear and the throttle response is awesome for getting on the freeways no turbo lag it just gets up and goes. In ECO mode seems to shift to higher gear quicker and it is different in all 3 settings.
