- First Name
- Aaron
- Joined
- Jul 8, 2025
- Threads
- 3
- Messages
- 83
- Reaction score
- 93
- Location
- North Carolina
- Vehicle(s)
- 25 ORPH
The OE Toyo Open Country AT IIIs are rated 116T, which means 2756lbs @ 44psi and 118mph sustained speed. Using the ETRO published data here for load ranges at inflation, and their general guidance of 10% of max safe speed reduction per 10% pressure reduction, it would look like this:This is immensely helpful. I'm embarking on a long trip with a lot of rough gravel and dirt roads and my question would be if it's even feasible (or safe) to consider airing down 5psi (from spec 33psi)to make for a more comfortable ride with these OEM Open Country tires.
I'm having to extrapolate here a bit, but it seems at 33psi were looking at each tire capable of holding ~2270 pounds and when airing down to 28 for a gravel road that drops to ~1900 pounds per tire. 1900x4 =7,600. Assuming a fully loaded Trailhunter (GVWR is ~6500 pounds) were still within ~1100 pounds but the margins are clearly at a limit.
Am I thinking about this right? It seems unwise to go any lower than 28psi with these OEM tires but at this point I'm looking for some extra guidance given I can't find any concrete PSI charts with these OEM tires. What say you experts? ...I rather wear out these tires before replacing them myself.
| 24 | 25 | 26 | 27 | 28 | 29 | 30 | 31 | 32 | 33 | 34 | 44 | |
| Load | 1982 | 2028 | 2116 | 2178 | 2216 | 2304 | 2392 | 2433 | 2491 | 2579 | 2619 | 2756 |
| Speed | 64 | 67 | 70 | 72 | 75 | 78 | 81 | 83 | 86 | 89 | 91 | 118 |
OE manufacturers set the tire pressure based on the needed load capacity + 10% safety margins, so you COULD read the table and say you could drop to 29psi and merely be at the needed load capacity. You just need to know to slow down if you're gonna air down
Could you air down to 28psi for comfort on gravel and rough roads? Yeah of course. Will it be a bulletproof setup with no risk? Ehhhhhhhhhhhh. Toyota picked 33psi for a reason. If it were me, I wouldn't go lower than 30psi on the p-metric tires, and I would ready to change a tire if need be
