Dead Horse
Oklahoma
I'm going to do the same grill swap on mine, I'm assuming you used one of the aux switches...Which one did you use, and was it as easy as it looks?
And how do you like that Heretic light bar?
4rsreed
4rsreed
Ryan
Arlington VA
2025 4Runner Off Road Premium Hybrid
I had my grille swap done by "Trick Trucks". I really like the Heretic Light Bar. It puts out a lot of light. They installed off the Aux Switch 1. I was hoping that they could just pull out the Aux Switch and replace it with the Rave Auto TRD Light Bar supplied switch. They said they weren't able to do that, but they slaved the Rave Auto switch to the Aux 1 and put the Rave Auto Light Bar switch next to the tail gate switch on the dash which isn't as elegant of a solution that I was looking for, but it works.
4rsreed
4rsreed
Ryan
Arlington VA
Do you plan on changing the wheels and tires?
My plan is to run the tires until they need to be changed and then pick up some OEM TRD Pro wheels. I am going for an OEM+ look on the TRD Off Road.
