Loud Humming Noise After Suspension Install
jjb07
Jairon
Norwalk, CA
2025 4runner trd off road
My 2025 4Runner Trd off road developed a loud hum after Ironman IM 2.5 install. It has about 2.5” lift in the front. The hum is prominently heard in the front driver side. I can also feel slight vibration on the accelerator pedal. I read with the previous generation that it could be the needle bearing. I got all terrains Nitto Terra grapplers btw. Could it be the same issue? If not, what could it be?
Ltd.Herit.'26
Austin
Dallas
2026 4Runner Limited 4wd
If you did lift/tires at the same time, best case scenario is a better balance on your tires.
AZGOLD
AH
Prescott
2025 ORP 4runner
Putting an iron man lift on, may have been the first problem.
1. absolutely need an alignment.
2. Rebalancing tire/wheels
3. Never had a “needle” bearing issue on any of my 4 runners, only on a Tacoma I had, but that was a bad differential design.
good luck 👍
jjb07
Jairon
Norwalk, CA
Solved. It was the needle bearing. Issue resolved after Ecgs clamshell bushing was installed.
gvan1998
MD
good luck 👍
Why do you need to rebalance the tires for lift?? You dont make sense. If the tires are balanced, it shouldn't matter whether you have 10-inch lift or a 1-inch lift. The tires are balanced off the car,
mcd_ovrlnd
SE PA
2025 4Runner TRD PRO
Found this thread and wondering how you are feeling about the Ironman setup now?
MARK4A3
Kitsap County, WA
26 4Runner ORP Hybrid
My runner has a front end hum/vibration but in 4hi. Goes away when I switch to 2WD. Most of the symptoms I read are opposite.
This truck had a leveling kit installed by dealer and 33s installed by dealer
