Installing volume knob - how to get access to the back of the air vent?
Russ
Russ
Can anybody tell me how to get access to the back of the air vent? Thanks.
2025 2026 4runner 6th gen Installing volume knob - how to get access to the back of the air vent? IMG_0064
Rellims
Sean
ORP - Underground
How is this even possible with the screen in the picture?
well it depends. the 8in screen has the volume knob in the bottom left of the screen.
the 14in screen has the volume knob between the vents.
since he is doing a retro fit, and didnt buy a kit with instructions, he will have to get a dash expanded view to see how to remove the vents.
i am guessing he will need to pull the center console stack and maybe the center console lower section to get access to remove the vents to install the retro fit vent cover with volume control module
thats if he ordered the volume control module which i am guessing he didnt since he is asking how to get to the volume control knob.
also will have to order the wire harness to connect the volume control knob.
not sure what they ordered since its just a random post with hardly any details.
Russ
Russ
Russ
I have all the parts mentioned…just don’t know how to get access to the back of the vents for the install.
you will need to get a exploded view of the center console to figure out what needs to be taken apart.
maybe someone with access to a parts breakout or exploded view can help.
and the printer is you friend :)
Russ
Russ
Russ
Thanks for all the input guys. 😊
luisdaperzm
Luis
NKY
4Runner SR5
Hey Russ. I’m trying to retrofit a 14in screen from a Tacoma the same way you did it.
Did you have to change the plastic trim around the gauge cluster ?
Any input would be very appreciated for me!
Russ
Russ
Russ
Hello…nope, should be straight plug and play.
