Engine Immobilizer - Insurance Requirement
thirstyross
Ontario, Canada
2025 4runner
Just wanted to note here, because I saw someone post somewhere that their insurance company suggested they needed to get the Tag system - I got the same line from my insurance company and when I said I installed the Ghost immobilizer, that was acceptable to them as well. It just has to be a certified installation.
HedgeHog
HedgeHog
Rob
Georgetown, Ontario
Toyota 4Runner
The 2024 Tacoma is on the Top 10 stole most stolen in Ontario and, I saw it on CAA’s list when I uploaded the proof of installation. The agent said that although the 2025 4Runner is not top 10, its also too soon to make that determination, hence the reason they make it a requirement to have one installed.
kobyneal
Rich
Calgary Canada
2024 Prius & 2026 4Runner
Double checking - going to get IGLA installed next week - for anyone that had that or similar installed - no issues to date? Install went well?
horbit
DFW
I have IGLA and have not had issues. Feel free to ask questions.
IGLA Help
IGLA INSTRUCTIONS | Earmark Car Audio
*Edit* - I remember one thing, instead of the gas pedal, activate the high beam to program the IGLA.
kobyneal
Rich
Calgary Canada
IGLA Help
Much appreciated! I think I’ve learned as much as I can about how the system works in theory, but wanted to confirm in real world example with a 4R.
Regarding your comment about the high beam - like add the high beam into the code or some thing to mention to the installer?
horbit
DFW
The gas pedal is mentioned as a "button" to use during a few procedures, instead on the 4runner you have to pull the high beam. This is only for a few tasks and not related to normal operation. Look at the second link I posted to understand what that means.
Also I was able to enable\disable anti-carjacking myself after syncing the device to the author connect 2.0 app on my phone. Among other settings. I don't recommend using the button on the shifter for anything since when in drive, that button didn't seem to register :). When the anti carjacking feature turns on its quite scary haha.
kobyneal
Rich
Calgary Canada
Also I was able to enable\disable anti-carjacking myself after syncing the device to the author id app on my phone. Among other settings. I don't recommend using the button on the shifter for anything since when in drive, that button didn't seem to register :). When the anti carjacking feature turns on its quite scary haha.
Extremely helpful thanks so much.
green_tips
James
I had the IGLA installed and had a couple issues to share. Overall I'm happy with it and would definitely recommend getting it installed. But a few things to be aware of:
Be very careful inputting the code buttons, the installer will probably coach you on it, but after you first hit the ignition before you authorize, wait till all the startup chimes are done before you put in the code. Put in the code slowly and make sure you get the acknowledgement flash/beeps before you hit the ignition button again. The buttons can be a little finicky so make sure you press em good. Be really careful with remote start too - same thing, take it slow when entering the code.
I had an issue a couple times where I rushed it a bit, not waiting long enough after the initial chimes/flashes to finish before putting in the code, or hitting the ignition too quickly after authorizing and this caused a bunch of Toyota error messages on he dash. Basically put the truck into limp-home-mode and turning it off and trying to re-authorize did not work.
If something like that happens to you, all you have to do is turn the truck off, disconnect the battery for ~7min and then reconnect it - this clears the codes and you're good to re-authorize and go.
Quite inconvenient if it happens, but now that I'm much more careful about entering the code and being patient I have not had any issues. It is a little annoying to put in a code every time you drive but not as bad as waking up to an empty driveway.
kobyneal
Rich
Calgary Canada
This is great thanks for sharing! So part of this as well I assume is ensuring the code you choose is using buttons or whatever that are distinct vs potentially vague (ie. Aux 1 button vs volume toggle on the steering wheel). Does it only give you one chance to enter the codes an start up before it goes into limp mode?
green_tips
James
Yeah exactly - the installer told me there were only certain buttons that would work with the system, but there's still enough combinations that its not guessable. I don't think the Aux buttons are part of the options but that might just be because of my installer. Pretty much all of the steering wheel buttons worked, but I don't think any of the radio or climate control buttons worked. I actually don't know if there is a limit to how many code attempts you get, but I think the most I've put in before getting it right is 3 tries. The most important thing is to wait for the system to accept the code before you try and start the truck.
The whole sequence is foot on brake and hit starter button; after you wait for the start up chimes to stop, enter the code; then your dashboard will flash up some indicator light (I'm not sure if which light or sound it makes varies based on how the install is done) with a chime or beep to let you know the code was accepted; and then after that you can hit the ignition button again with your foot on the brake and the truck starts up.
Entering the code while using the remote start is similar: Start the vehicle remotely; once you get in, enter the code; wait for the authorization acknowledgement flashes/chimes; hit the starter button with your foot on the brake and you're good to go.
