MikeTheBiker
Mikey
26 ORP Gas
I came from a gen4. On the gen4, the rear was flat with no mods. Toyota, in their wisdom, removed this as part of the design for the gen6. So, I DIYed my own platform to level the rear for sleeping in the back, with added stoage. Here are the quick details:
- 26 ORP gas
- rear seats removed (no dash lights)
- 2 x 4s on end for added height to store stuff. since its sloped near rear seat area, there is more storage under there.
- entire frame is in 2 pieces for easy install and removal.
- platform is roughly 44 inches wide at narrowest. And 66 inches long.
- both front seats and go all the way back, and fully recline.
- platform made of 3/4 inch plywood.
- platform is in 4 section, all removable.
- frame is anchored in 6 total places: 4 using rear seat attachment points, and 2 from rearward cargo net attachments.
- Approx. $200 in cost for supplies.
- covered in a cheap felt. This felt probably not going to last that long.
Quick story behind it:
My use case is I like to sleep in the rear of my 4runner while stealth camping and remote camping. Depending on where I am, I need to change clothes back there, and I like to be able to sit up in bed. So the platform needs to be as low as possible.
I started by ordering a BamBed Solo. I instantly hated it. There was just no room above the bed. it also takes up an enormous amount of space. I returned it. (note: if you order a BamBed, be very sure you want it, as they have an expensive restocking fee, plus you pay return shipping. Was an overall expensive return). It was my mistake, not BamBed's. But the whole Bambed experience sucked.
In lots of online research, there are just no platform options out there. All are very expensive drawer systems, which take up more space than Im willing to give up. I also do not need drawers. I also do not want to remove any carpeting. I can have my platform out and rear seats back in, in under an hour.
I welcome comments or critiques. This is still a work in progress.
2025 2026 4runner 6th gen DIY leveling platform with storage 20261029_162145
2025 2026 4runner 6th gen DIY leveling platform with storage 20261029_162124
2025 2026 4runner 6th gen DIY leveling platform with storage 20261029_162108
Joe Dirt
And that's all you need. I have absolutely toyed with the same idea. Only I was not even going to put a frame down, just a memory foam pad with a couple of 10 in tall storage containers to hold my air compressor and all my ditch gear plus extra blankets and some cooking stuff.
Easy to strap down.
And like you say It can all be taken out in minutes. I'm sure yours is much more comfortable and you have a stable platform. Especially like the hidden compartments under the sleeping platform , Very nice.
MikeTheBiker
MikeTheBiker
Mikey
26 ORP Gas
Easy to strap down.
I was also just going to lay plywood directly down flush to the rear. But i measured all the crap i carry around, and it would all fit in under 3 inches, except my small floor jack and bottle jack, which fit in the sections closer to the front. An entire bins worth of junk is now under the platform, with plenty of space left for more.
Ive got a couple hundred miles on this now. Its totally fine, so far. its made the cabin more quiet as well. I threw the rubber mat from the rear on top, so it somewhat protected from leaky trash bins and such.
sachelis
Steve
Salt Lake City UT
2026 Toyota 4Runner Sport Premium
Was building a box necessary after you removed the seats? It seems like the box decreased the headroom you desired (albeit only by 4").
MikeTheBiker
MikeTheBiker
Mikey
26 ORP Gas
Not necessary. My plan A was to just level it out. But that 3.5 inches that the box gave me in height actually holds an enormous amount of gear. I almost went 2x6, but wanted to keep the headroom, so 2x4 is where I landed.
Im also trying to keep my roof clean of racks and boxes. An argument could be made for just leveling the rear flat, and tossing all the gear into rooftop boxes. But this is my daily vehicle, and all that wind noise and loss in fuel economy would be annoying to me. I'm considering removing the side rails for the roof rack even,.
