Van Solo
Van
Calgary / Canada
Van Solo
Van Solo
Van
Calgary / Canada
Step 3: Deleted / Removed from build
Rago GMRS / Ham Mount attached to Ditch Light Mount.
2025 2026 4runner 6th gen Diode Dynamics / Stormtrooper Lighting Build 514i2bJTEHL._AC_SL1200_
The mount will not fit as intended you would need to have it mounted towards the inside so we decided it's a no Go!
Van Solo
Van Solo
Van
Calgary / Canada
Step 4:
Installation of .............@DIODE DYNAMICS C2 2.0 ......... Stay Tuned this weeks completion and full review - Testing
"LIGHT UP THE ROAD"
These Combo/Driving lights are Brighter than my last lightbar!
They have a dim amber mode that we set to the Aux 3 for night time coasting or hanging out at camp, then the Brightness gives way when we engage the Aux 4 and total white light that's well above any standards I have seen or used before....Clear Crisp white light that truly has no distortion or feathering at all.
Installation was very simple thanks to the wire harness we got for Diode Dynamics, the 4 pin heavy duty harness connected to the factory pigtail with ease.
Keeping the installation clean with additional loom and routing the cables via the engine harness for a stealth clean look.
We will add more night time images and outside performance shortly....
***Our next will be the C1R+BRAKE by @Diode Dynamics follow this review as we continue our @Diode Dynamics light builds......
2025 2026 4runner 6th gen Diode Dynamics / Stormtrooper Lighting Build tempImagecOFVBj
The kit we will be installing is @Diode Dynamics C@ 2.0 Driving Combo Pro Series with the wire harness kit that includes pigtail connections.
2025 2026 4runner 6th gen Diode Dynamics / Stormtrooper Lighting Build tempImageF69GYq
Routing the wires on the passenger side behind the plastic inner fender guard.
2025 2026 4runner 6th gen Diode Dynamics / Stormtrooper Lighting Build tempImageLZErwi
The power line to the fuse box tied in with the power cable from the hybrid motor.
2025 2026 4runner 6th gen Diode Dynamics / Stormtrooper Lighting Build tempImageFIYLE
Routing the cable via the the grill towards the pigtail location.
2025 2026 4runner 6th gen Diode Dynamics / Stormtrooper Lighting Build tempImageeDcNAg
Loomed the light cables.
2025 2026 4runner 6th gen Diode Dynamics / Stormtrooper Lighting Build tempImagekYsAnT
The main light cables routed via the existing engine cables for a factory clean look.
2025 2026 4runner 6th gen Diode Dynamics / Stormtrooper Lighting Build tempImagemYXe5
@Diode Dynamics harness into the pigtail.
2025 2026 4runner 6th gen Diode Dynamics / Stormtrooper Lighting Build tempImageSIDtiH
Fuse box used.
2025 2026 4runner 6th gen Diode Dynamics / Stormtrooper Lighting Build tempImageDydauz
Aux 3 is to be used for the backlighted amber (Black pigtail).
2025 2026 4runner 6th gen Diode Dynamics / Stormtrooper Lighting Build tempImage61GeQc
2025 2026 4runner 6th gen Diode Dynamics / Stormtrooper Lighting Build tempImageVx9PzT
2025 2026 4runner 6th gen Diode Dynamics / Stormtrooper Lighting Build tempImageWg38nk
2025 2026 4runner 6th gen Diode Dynamics / Stormtrooper Lighting Build tempImageQqS6Wd
Aux 4 used to power main lighting of th eC2 2.0 lights.
2025 2026 4runner 6th gen Diode Dynamics / Stormtrooper Lighting Build tempImagenybupB
2025 2026 4runner 6th gen Diode Dynamics / Stormtrooper Lighting Build tempImagerGyOjZ
Van Solo
Van Solo
Van
Calgary / Canada
Im just gonna say these lights remain small in size but great in light output, why would anyone use those large cubes I have no idea?
EZink
E
texas
2025 4Runner TRD PRO
Inspired by your build.
How did you wire/use both aux 3 & 4 with only one pigtail adapter provided by DD?
2025 2026 4runner 6th gen Diode Dynamics / Stormtrooper Lighting Build imag
Van Solo
Van Solo
Van
Calgary / Canada
Will do guy's just on vacation. please see images in post for now.
Used the passenger side fuse box and ran power via the rear inlet.
Ground wire to the body.
Pigtails has multiple power feeds and a ground each feed is a separate AUX button.
Van Solo
Van Solo
Van
Calgary / Canada
Use the Toyota OEM pigtail it has 4 leads each lead offers a separate AUX, in our case we are using the lead that offers Aux 3 & Aux 4
Use Aux 3 amber light output
and Aux 4 Main output
or use the white from pigtail as its ignition on (Amber lights on while vehicle is on)
Van Solo
Van Solo
Van
Calgary / Canada
Soon we will be installing the New C1R+Brake on our 4Runner.
Canada Post Delayed?!
Harness Length: DT connector to inline harness: 25.59 inches
Datasheet(s) (click to download): SSC1 Sport White Standard
Measured Lumens: SSC1 Sport: 1,030 lm, C1R: 1,080 lm
Intensity (cd): SSC1 Sport: 400 cd, C1R: 480 cd
Color Temp (CCT): 6000K
Power (watts): SSC1 Sport: 12.8, C1R: 14.1
Operating Voltage: 9-16V
Current (amps @ 12.8V): SSC1 Sport: 1, C1R: 1.1
Polarity: Polarity Specific
Operating Temperature: -40C to 85C (-40F to 185F)
LED Emitter: Cree XP-L HI, Osram 1414 Pure
Connector(s): Deutsch DT Input
Driver Features: Constant Current
Materials: Polycarbonate Lens, Aluminum Casting, Rubber Gasket
Cooling: Passive, Pin-Fin heatsink
Compliance Ratings: SAE J575 Durability Test
Intrusion Ratings: IP67 Weatherproof
Unit Weight (lb): 0.35
Product Weight (lb): SSC1: 0.95 C1R: 1.0
