Can’t fix TRD PRO Steering wheel vibration!
kingf14
george
ohio
4 runner
Found a possible solution atleast its fixed multiple that I've had the trd pro wheels were not designed properly for the hub on the front of the 4 runners and tacomas the front axle bearing cap catches slightly on the wheel not allowing the wheel to sit flush on the hub even after torquing the wheels. Remove the black caps and test drive bet It goes away.
Pierrous1
Pierrous1
Pierre
Orlando, FL
2025 Toyota 4Runner TRD Pro
Thanks for the tip, kingf14! I can't believe it's something as simple as that - unfortunately I got rid of the 4Runner last year....just couldn't deal with the vibration! Loved everything else about it. Hopefully someone on here can try that fix and report back to the forum.
