Bad CV axle angle
Dead Horse
Oklahoma
Im not familiar with the suspension in the OP but some general theory on lifts and CVs…
Of course, if you lift, you’re pushing the front differential up relative to the hub on the wheel, so the CV angle increases. Max droop is controlled by shock length (plus any spacer) so if you have not extended the shocks or added spacers the CV will not bind at full droop and should run fine at the new angle. However, if you extend the length of the strut via a spacer or a longer shock, at full droop the CV angle can exceed design specs and bind or break. That’s probably why the TRD lift includes axels… they can handle the added articulation without binding.
This is why spacer lifts shouldn’t be off-roaded. They make it possible when the shock is fully extended that the CV could be past the design limits and bind. If you ever get one wheel in the air you can snap an axle. But this is not a real problem for a street vehicle.
Preload lifts are really just compressing the spring - trading down travel for up travel. So if the factory setup is 3” of articulation up and down, and you install a 2” preload lift, you’re now getting 5” of up travel and 1” of down travel. In other words pot holes will easily cause the shock to bottom but there’s no risk to the CV joints.
I think people are too concerned about longevity of the CVs when the actual thing that breaks/bends first on most of these type of lifts is the shocks themselves. By the bottom shock mount.
2025 2026 4runner 6th gen Bad CV axle angle 1793071021875-ak
2025 2026 4runner 6th gen Bad CV axle angle 1793071376921-7c
griegert
Greg
Simi Valley, CA
2010 FJ Cruiser / 2025 TRD ORP
On a related note... This is what happens if you lose the top nut on the shock. Was in the mountains of Idaho and found this when I hit pavement. Never felt a thing and it handled normally.
In the dirt I must have lost the top nut, dropped the right front wheel and the shock pulled out and speared through the spring before the spring compressed. Bet I can't do that twice!
2025 2026 4runner 6th gen Bad CV axle angle 20260619_120145
2025 2026 4runner 6th gen Bad CV axle angle 20260619_120157
Virtual-Chris
Vancouver, BC
2027 4Runner
Your photos show what looks like significant spacers on there… What causes this? inappropriate or lack of bump stops?
Dead Horse
Oklahoma
Those aren't my pics. I've had it happen though. On Billstein 5100s on their middle (of three) notch. I'm assuming the industry may have caught up, because I haven't seen nearly as many failures on forums in the last few years.
In my (anecdotal) experience, CVs usually take a long time to fail due to a mild lift.
