ARB Roof Rack + Roam Box Mounting Kit
hussch85
Hussein
Cypress, CA
2026 4Runner TRD Pro
Hello 🖐
Has anyone installed a Roam Box or Mount on an ARB roof rack (trailhunter rack) ? I got the 95L on black friday but when I tried to mount the mounting kit , the screws seem too shallow. And after several discussions with my buddies (Chatgpt and Gemini lol) I dont want to order the sandwich plates or what not considering they won't arrive on time for my upcoming trip in a few days
any help would be appreciated
Dave West
Northern CA
Hello 🖐
I have the ARB 3/4 rack on my '25 ORP. ...I went to my Toyota Parts Dept for a mounting kit hardware for accessories. The only mounting accessory hardware was for the traction mud plates. I had them bring up a closeup of the bolts. Basically their Carriage Bolts you can get at a hardware store. So the head of the carriage bolt can't be any larger than 13/16 inch. The pivot stop square on the Carriage bolt can't be any larger than 7/16 inch...........What should be done is to purchase two 1/8 inch by 1' inch metal strips, And drill holes in the strips to match your travel roam box inside box Corners. Install the Carriage Bolts in the ARB Rack slider mounts. Install the metal strips into the holes and secure with back off clips. Mount the box and nut & washer down through the protruding Carriage bolts threaded extensions that come through the inside corners of the Roam Box.......
If you just need to tie down stuff; I modified the Tacoma optional inside bed slider tethers. See photos for specs of modifications.
Hello 🖐
2025 2026 4runner 6th gen ARB Roof Rack + Roam Box Mounting Kit IMG_2245
2025 2026 4runner 6th gen ARB Roof Rack + Roam Box Mounting Kit IMG_2244
hussch85
hussch85
Hussein
Cypress, CA
So I "temporarily" Figured it out !
Went to Home Depot and bought 1" M6 Hex Bolts , Nuts and Washers x2
worked perfectly where the bolt won't rub against the bottom of the Roam 95L Case
attached images of install along with items I bought from HD for ref
2025 2026 4runner 6th gen ARB Roof Rack + Roam Box Mounting Kit IMG-20251217-WA0009
2025 2026 4runner 6th gen ARB Roof Rack + Roam Box Mounting Kit IMG-20251217-WA0026
2025 2026 4runner 6th gen ARB Roof Rack + Roam Box Mounting Kit IMG-20251217-WA0027
2025 2026 4runner 6th gen ARB Roof Rack + Roam Box Mounting Kit IMG-20251217-WA0028
2025 2026 4runner 6th gen ARB Roof Rack + Roam Box Mounting Kit IMG-20251217-WA0029
2025 2026 4runner 6th gen ARB Roof Rack + Roam Box Mounting Kit IMG-20251217-WA0030
2025 2026 4runner 6th gen ARB Roof Rack + Roam Box Mounting Kit IMG-20251217-WA0031
2025 2026 4runner 6th gen ARB Roof Rack + Roam Box Mounting Kit Image 2025-12-17 at 21.24.02_6065d3b2
Don't think galvanized is your best option, might want to use marine grade oxide coated hardware.
hussch85
hussch85
Hussein
Cypress, CA
Ok ill make sure to switch em out thanks
hussch85
hussch85
Hussein
Cypress, CA
Update
Found these T slot screws and they fit perfectly
Pics of fitment and product link - will later post of images with Roam installed
DALQUIS 6 Pack T Slot Bolts for Roof Rack Cross Bars | M6x30mm Stainless Steel Square Track Adapters | 4mm Thick | Easy-Fit https://a.co/d/08GBzjrD
Nuts
M6 x 1.0mm Nylon Insert Hex Lock Nuts 50Pcs 304 Stainless Steel Locknuts, Hex Drive, Bright Finish, by SG TZH https://a.co/d/0j4TIpA9
2025 2026 4runner 6th gen ARB Roof Rack + Roam Box Mounting Kit IMG_7655
2025 2026 4runner 6th gen ARB Roof Rack + Roam Box Mounting Kit IMG_7654
ThatSickRIp
TSR
2026 4Runner SR5
Update
Nuts
Nice find. Those look perfect for a tote I want to try to mount to my roof rack before dropping hundreds on a Roam or similar.
