Advice needed: 35's not fitting so go to 34's?
famrunner6g
2025 4Runner TRD Off Road Premium i-FORCE MAX
famrunner6g
They're in my garage and I'm scared lol
famrunner6g
Here's a good response that has me hopeful https://4runner6g.com/threads/34-ti...with-no-lift-level-or-trimming.784/#post-2630
The 285/75R17 Falken Wildpeak A/T4W translates to a 34.1-inch diameter and an 11.2-inch width. That tire will fit, especially with a +30mm offset. You will have a little poke, but nothing too aggressive at all.
You might be able to get away with just removing the mud flaps in the front and maybe removing a crash plate in the wheel well for the wheel to fully lock forward and reverse.
You shouldn't have a problem with that tire. I don't foresee trimming of the front bumper or sheet metal at all, though.
2025 TRDOR 4Runner
I'm happy to help but I need the width of the rim not the tire size.
famrunner6g
Thanks! Fingers crossed. I'll post updates
famrunner6g
Awesome! Thats reassuring. Thanks!
lb1606
FL
@carpartsclemons Can I do 265/70R17 with 17x8.5 +25 offset wheels without rubbing and no lift? Thank you in advance
lb1606
FL
8.5” may rub on the inside. I can’t tell you if they will work or not. But the will poke a bit on the front.
Looking at Icon wheels, they only have +25 offset wheels that has a 95.1 center bore size. If I go with 265/70R17 with 17x8.5 +35 offset with stock suspension/no lift, will it still rub at full lock?
2025 TRDOR 4Runner
17x8.5 et35 will for easier than 17x8.5 et25. Et35 will sit inboard 10mm. The more poke the harder it is to fit without rubbing (how much depends on each car).
lb1606
FL
17x8.5 et35 will for easier than 17x7.5 et25. Et35 will sit inboard 10mm. The more poke the harder it is to fit without rubbing (how much depends on each car).
Thank you
