5k service. poor customer experience.
CO/ZA
Denver
25 4R ORP
I will try this for my windshield. I feel smearing only happens during rain and noticeable at night for sure. Thanks
I had this same problem, only worse, with a brand new VW GTI I bought back in 2014.
Wipers would chatter in plain rain, smear, skip, etc.
Tried new wiper arms under warranty, different wiper blades from VW, Bosch, /Valeo SWF -everything!
To finally remedy the issue, I eventually figured out it must be the porters and PDI people hosing the car down in spray wax or using Rain-X or something prior to delivery.
Eventually I used a DA polisher with a German glass polishing compound to mechanically remove the film and it was good as new.
To this day I use home brew glass cleaning mixture for the outside glass comprising of 30% vinegar, distilled water, dawn dishsoap, and 91% alcohol.
Does a great job at removing the film from road spray, leaky trucks, and oily deposits.
If anyone is also looking at replacing the factory wipers, these Euro spec Bosch ones are excellent: https://a.co/d/7tBgVSj
Moby
Moby
NJ
TRD OR Premium
Thanks! Inwill try that
glocke12
greg
PA
6th gen TRD Off Road Premium
Hi guys!
so far absolutely love the ORP trim. Great ride, very comfortable.
overall i think Toyota has definitely cut some corners by using cheap materials such as bad windshield wipers/ seems to make a lot of noise from motor and smears but no streaks, windshield fluid that freezes even at 32f and brakes squealing in reverse.
Took the vehicle for 5k first service with oil change. The advisor first said that i don't need oil changed as Toyota recommends at 10k but when i said that still need an oil change, the guy then said GREAT IDEA to get oil change at 5k. About 100 sonjo biggie.
I asked advisor to check motor perhaps the tension on the wiper and to top off the windshield fluid with an actual fluid that will work, but the guy said something that was absolutely out of this world.
so he said that i see some smearing from build up of stuff that gets stuck on the windshield all day so he advised to clean the windshield every morning. Regarding the fluid the guy said to heat the windshield before using the fluid.
now having been a driver for over 30 years using so many car brands and service depts, the quality and responses of this adviser was so bad that i come to a conclusion that Toyota has lost it.
I live in NJ where we dont really have very harsh winter anymore. Fluid are not supposed to freeze in these conditions regardless if i heat the windshield. Rain will also clean the windshield which we get often in nj. Also get regular car wash so incant see any possibility of junk sticking onto the windshield so much that a 6months old vehicle with wipers and fluid perform so bad.
Tire rotation was also only done for the 4 being used and not the full size spare. I was told that its not needed and thats why the air pressure is so high in spare. Even though, this was BS but leaving a spare tire for emergencies was ok so didnt want to argue with the guy. Plus the kind of rotation recommended by toyota will leave 3 tire on one side used differently.
For brake squealing, the guy said the brakes build up rust and is normal and goes away once you drive it. He claimed that he has never seen this issue before. I already knew about the TSB available on this forum and on doing a quick google search, i showed the advisor the report and he said that he will order the parts and take care of it.
Overall, poor customer service at Toyota
In NJ ? What dealership ? I've been to the team Princeton dealership and was not impressed with the service there at all.
Moby
Moby
NJ
TRD OR Premium
Autoland Springfield
JasonNewYork
Jason
Franklin Square, NY
Honda CRV
Moby,
I feel your pain. I'm in the NYC/LI area and had my windshield washer fluid freeze up multiple times this winter. I bought a fluid pump and plan to remove it one day this week. I bought -20F fluid from the auto store. Never had this problem before with other makes/models.
I brought my SR5 in for the free 5K service. They rotated the tires, I can see from the varying levels of brake dust this was completed. They did not reset the maintenance required warning despite it flashing on the IC when you turn the car on. They also overfilled the tires to 36psi, should have been 33. I'm doubting they reset the TPMS system after rotating and will check that this week as well. I asked the dopey service writer kid about the brake squealing TSB and he said he had no clue, never heard of it before. This was after I told him my brakes squeal backing up in the morning or damp/humid conditions. I will deal with this at the 10k service.
I would say this not a Toyota problem but more of what to expect living in or near a major metro area. Customer service is pretty non-existent anywhere I go.
