17x8 +12 Offset + 285/75/17 or 295/70/17 + No lift = Possible?
xp0nex
2025 4Runner ORP
Have some new wheels coming in soon that are 17x8 with +12 offset. Looking to see if anyone has done or know if I could stuff either 285/75 or 295/70 without a lift. I do not plan on going rock crawling / off roading. Just needs to be able to mall crawl with the usual stuff you'd find on the roads (speed bumps, inclines, etc.) without rubbing.
papadop88
2025 4Runner TRD Pro
With a +12 offset with 75s or 70s, you'll be rubbing pretty good with no lift. Nothing that can't be fixed by removing the safety plate and a little bit of trimming up front.
Agree with Papa. 285/75/17 are slightly larger diameter (33.8") than the 285/70/18 (33.7") I put on my TRD ORP. At +25 offset I had to remove crash plate and bend up tab for air dam screw and still had some slight rubbing of forward felt in reverse. Switched to +45 offset and the felt rub is gone (not sure if I can put the crash plate and air dam back on but am going to test that just for fun).
The 295/70/17 at 33.3" MIGHT fit but with that +12 offset and additional width I think its highly likely they will rub. MIGHT work with OEM +55 or TRD option +45 wheels. (I'm virtually certain that I could fit 275/70/18 at 33.2" without rub on +25 - but that extra 10 mm of width and - 13 mm offset makes me say maybe for you)
Caveat to those with other trims: the suspensions are different and this analysis based on my specific experience will not hold. (E.g., the extra inch of ground clearance (assumedly from strut length?) and designed +25 offset of the PRO & TH mean these tire sizes are more likely to work on those trims - and even less likely to work on lower ground clearance trims (SR5, Sport, etc.).)
xp0nex
2025 4Runner ORP
Good to know. If I do decide to lift, I'll most likely get the Peaks 1.25" lift. Kept telling myself I didn't want a repeat of my Tacoma again. If the 1.25" and a good alignment is all I'll need to clear one of those tires I might just do that, if not, then I will settle with getting 285/70/17 to fit.
