- First Name
- James
- Joined
- Mar 17, 2025
- Threads
- 12
- Messages
- 112
- Reaction score
- 121
- Location
- St. George, UT
- Vehicle(s)
- 2025 4Runner, 2011 4Runner
- Thread starter
- #1
Hey guys! We've got something new from AAL: a mount for the Harbor Freight BADLAND 1.5 Ton Off-Road Jack.
If you've been figuring out where to keep your jack in your 4Runner cargo setup, we'd like to hear what you're working with. We built this mount around keeping the jack, both handle halves, and the Allen wrench together.
We cut and form the mount from 5052 aluminum right here in St. George, Utah. It weighs 3.3 lb and comes in Raw/Unfinished or Textured Black. We do the black powder coating in-house too.
A few details we worked into it:
This mount fits the BADLAND 1.5 Ton Off-Road Jack, item 70887, only. It doesn't fit the 3-ton model or other jacks. The jack, mounting hardware, and optional padlock aren't included.
For planning your setup, the mount has 7 mm holes with a 6-inch lengthwise and 3-inch crosswise center spacing. Check the hole layout and instructions against your mounting surface before deciding where to put it.
Product details and current pricing
Installation instructions
Where would you want to mount your jack in your 6th-gen 4Runner? Tell us what cargo layout you're running and whether yours is a hybrid or non-hybrid. We'd like to understand what space you have available and how you'd get the jack in and out without unpacking everything.
And if you're carrying the 3-ton BADLAND instead, let us know. We're interested in hearing how much demand there is for that mount too.
Thanks, guys!
The AAL Crew
- Cushioned, offset supports hold both handle halves snug underneath the jack. The offset accounts for the foam-covered half being larger in diameter.
- A small cradle tucks behind the Allen wrench release button to help keep the wrench with the jack.
- A retaining bar uses the included hitch pin and R clip. The pin also accepts an optional padlock with a 3/16-inch shackle.
- It ships fully assembled. You'll supply mounting hardware suited to your mounting surface, using 1/4-20 or M6 bolts.
Thanks, guys!
The AAL Crew
