Van Solo
Van
Calgary / Canada
Hey Van thanks for your question and points. Iโ€™ll try my best to tackle them point by point.
1. The width will be reduced by half an inch and height increased by 2 inches. The real problem I might have is in the increase in scrub radius. But in terms of safety, these tires will provide better load bearing capacity than OEM falkens.
The pizza cutters are known to have better performance in snow than their wider counterparts.
2. Speedometer isnโ€™t much of an issue, something that we will learn to adapt too
3. Narrower tires with lower psi actually offer more grip. And going through the snow in MB I think I will gain an edge. Not lose it
4. As for aesthetics, I donโ€™t mind it at all
5. As for potential for increased wear, Iโ€™ve โ€œoffsetโ€ that as best as I could with the +30mm offset while increasing 2โ€ in height. The narrow tires will mean I will be doing less wheel well modifications to fit 34.5โ€ tires
Alright then Brother you got it sorted,
Haruharu
Garth
Winnipeg
4Runner TRD ORP
Installed the tires and rims, slight rub on mudguards. Getting alignment tomorrow.
Running 255/85/17 Mickey Thompson Baja Boss R/T
34.5โ€ x 9.9โ€
Only had to trim mud flaps to fit. Caster 3.1 degrees
2025 4runner 6th gen ๐Ÿ‡จ๐Ÿ‡ฆ Ice Fishing Build - Dual Swing-Outs/35โ€/Winch Pizza cutter Baja Boss tires 255:85:17 - 34.5โ€ x 9.9โ€
2025 4runner 6th gen ๐Ÿ‡จ๐Ÿ‡ฆ Ice Fishing Build - Dual Swing-Outs/35โ€/Winch Pizza cutter Baja Boss tires 255:85:17 - 34.5โ€ x 9.9โ€ on 2025 4runner trd orp off-road 6th gen
2025 4runner 6th gen ๐Ÿ‡จ๐Ÿ‡ฆ Ice Fishing Build - Dual Swing-Outs/35โ€/Winch Mickey Thompson Baja Boss R:T Pizza cutter tires 255:85:17 - 34.5โ€ x 9.9โ€
Twomstone
Connor
Manitoba - Canada
NA
34.5โ€ x 9.9โ€
Pizza cutter Baja Boss tires 255:85:17 - 34.5โ€ x 9.9โ€.webp
Pizza cutter Baja Boss tires 255:85:17 - 34.5โ€ x 9.9โ€ on 2025 4runner trd orp off-road 6th gen.jpeg
Pizza cutter Baja Boss tires 255:85:17 - 34.5โ€ x 9.9โ€ on 2025 4runner trd orp.jpeg
Mickey Thompson Baja Boss R:T Pizza cutter tires 255:85:17 - 34.5โ€ x 9.9โ€.webp
Looks awesome! I'm also in Winnipeg (Blue ORP). I asked about some tire details in another post but curious if the no rubbing (small trim to rear) was with your lift you have now or before?
Haruharu
Garth
Winnipeg
4Runner TRD ORP
lovely! I think Iโ€™ve seen you on the roads or my wife has at least. Seems thereโ€™s a few of us.
I got rubbing, on the flaps only, even with the lift. Without the lift would have been the same. As I understand, rubbing has more to do with offset and tire dimensions than it has to do with lift. Hope this helps
204runner
Manitoba
2025 4Runner TRD ORP
Sick build man! I'm also from Winnipeg with a 6th gen trd orp blue. It's all stock right now and it handled pretty well from yesterday's storm. I wonder how did the baja boss' handle? Looking to upgrade in the future.
Haruharu
Garth
Winnipeg
4Runner TRD ORP
Terrific, drove down the perimetere in crosswinds and it was fine. We've also been ice fishing on it with 2 feet of snow and its been great. I will say if your priority is winter grip, there are definitely better options in the Nokian Hakkapellitas LT3s!
Haruharu
Garth
Winnipeg
4Runner TRD ORP
Hey all! Some quick updates
I went with @CAMTuning with a Cobb Tuning Accessport. Cam was kind enough to preload the tune file so I could get it going as soon as I picked it up. A full review to be done later
2025 4runner 6th gen ๐Ÿ‡จ๐Ÿ‡ฆ Ice Fishing Build - Dual Swing-Outs/35โ€/Winch IMG_5823
Figure 1. Removing the kick panel to bypass the CANbus to install the tune.
2025 4runner 6th gen ๐Ÿ‡จ๐Ÿ‡ฆ Ice Fishing Build - Dual Swing-Outs/35โ€/Winch IMG_5825
Figure 2. OBD connected and Accessport installed.
I attached a video of the car in sport mode for anyone interested.
Haruharu
Garth
Winnipeg
4Runner TRD ORP
Next, installing the Auxbeam RA80 Switch Panel (Purchased through Amazon)
2025 4runner 6th gen ๐Ÿ‡จ๐Ÿ‡ฆ Ice Fishing Build - Dual Swing-Outs/35โ€/Winch IMG_5843
Figure 1. Auxbeam Switch Panel Box.
I have no experience whatsoever with electricity or working on my car. The install took about 2 hours with me taking my time and double-checking all my work.
2025 4runner 6th gen ๐Ÿ‡จ๐Ÿ‡ฆ Ice Fishing Build - Dual Swing-Outs/35โ€/Winch IMG_5829
Figure 2. Routing and connecting all the wires.
I opted to run the 10 feet long switch panel cable through the Driver's side firewall and ran it up behind the trim for a completely hidden install. I installed CaliRaisedLED's 2025 Auxbeam Switch Panel trim as well. It can be found by clicking here. Please note that I fixed the switch panel to the trim by using 2 small screws (1 on each side)that is supplied by Auxbeam.
2025 4runner 6th gen ๐Ÿ‡จ๐Ÿ‡ฆ Ice Fishing Build - Dual Swing-Outs/35โ€/Winch IMG_5824
Figure 3. Installed @Cali Raised LED Switch Panel Trim and Auxbeam RA80 controller.
2025 4runner 6th gen ๐Ÿ‡จ๐Ÿ‡ฆ Ice Fishing Build - Dual Swing-Outs/35โ€/Winch IMG_5832
Figure 4. Power connected!
Please note that I fuse tapped into the 10A fuse (Passenger side) "ECU IGP No.2." The fuse taps provided by Auxbeam are not compatible with the OEM fuses, so I was stumped. But if you flip over the Auxbeam Fuse and Relay Box Lid, you'll find spare fuses. I took the 10A spare fuse and placed it into the tap to complete. No CEL or warnings displayed!
Haruharu
Garth
Winnipeg
4Runner TRD ORP
Installed amber fog lights that came with the aftermarket grille.
2025 4runner 6th gen ๐Ÿ‡จ๐Ÿ‡ฆ Ice Fishing Build - Dual Swing-Outs/35โ€/Winch IMG_5839
Figure 1. Cut off the relay and harness, leaving just the positive and negative wires that supply the fog lights.
2025 4runner 6th gen ๐Ÿ‡จ๐Ÿ‡ฆ Ice Fishing Build - Dual Swing-Outs/35โ€/Winch IMG_5838
Figure 2. Stripped the positive and negative wires and connected them to the 10 amp fuse (slot 5) of the Auxbeam.
2025 4runner 6th gen ๐Ÿ‡จ๐Ÿ‡ฆ Ice Fishing Build - Dual Swing-Outs/35โ€/Winch RenderedImag
Figure 3. Only the driver side turned on. I checked the connection and the culprit was a flipped connector.
Figure 4. First time ever wiring lights!
Haruharu
Garth
Winnipeg
4Runner TRD ORP
Next up, Westcott Design's Low Profile Roof Rack + Molle Panels installation. This was quick as I had Kevin at CKAutoFab in Winnipeg install it.
2025 4runner 6th gen ๐Ÿ‡จ๐Ÿ‡ฆ Ice Fishing Build - Dual Swing-Outs/35โ€/Winch IMG_5730
2025 4runner 6th gen ๐Ÿ‡จ๐Ÿ‡ฆ Ice Fishing Build - Dual Swing-Outs/35โ€/Winch IMG_5727
2025 4runner 6th gen ๐Ÿ‡จ๐Ÿ‡ฆ Ice Fishing Build - Dual Swing-Outs/35โ€/Winch IMG_5762
2025 4runner 6th gen ๐Ÿ‡จ๐Ÿ‡ฆ Ice Fishing Build - Dual Swing-Outs/35โ€/Winch IMG_5764
Haruharu
Garth
Winnipeg
4Runner TRD ORP
Agency6 shovel and grab handles. I'm going to need to find better security bolts
2025 4runner 6th gen ๐Ÿ‡จ๐Ÿ‡ฆ Ice Fishing Build - Dual Swing-Outs/35โ€/Winch IMG_5791
2025 4runner 6th gen ๐Ÿ‡จ๐Ÿ‡ฆ Ice Fishing Build - Dual Swing-Outs/35โ€/Winch IMG_5790
Haruharu
Garth
Winnipeg
4Runner TRD ORP
Woolwax installaton and OkExpedition's Skid Plate. You can find it by clicking here. I picked this because it allowed for easy oil change (removeable panel for filter and oil drain plug) and I also did not have to deal with shipping from the USA.
2025 4runner 6th gen ๐Ÿ‡จ๐Ÿ‡ฆ Ice Fishing Build - Dual Swing-Outs/35โ€/Winch IMG_1761
Figure 1. OkExpedition Skid Plate.
Figure 2. Woolwax treatment to the entirety of the underside and wheel wells.
Figure 3. Skid Plates Installed.
Figure 4. Air Dam Removal for winter.
Twomstone
Connor
Manitoba - Canada
NA
Nice updates! I'm between Greenlane off-road and OK Expedition for skids. Might go Greenlane as I want a low-pro winch bumper too and rock rails so might try and get a discount if I buy all 3.
Was the thoughts for woolwax just the rough winters we have here for corrosion? How much was it?
