boblupo
Robert
For anyone wondering what the TRAIL EDITION rock sliders from @Cali Raised LED would look like (and how to install) on a 2025 TRD ORP, here you go. I sold the factory running boards on FB Marketplace and installed these. They are the Trail Edition (not Step Edition) which are still on sale 15% off. I got the Kick-out option, powder coated.
https://caliraisedled.com/products/trail-edition-rock-sliders-for-2025-toyota-4runner
They will contact you about the hardware needed - on the TRD ORP, only the front 2 holes on each side are threaded, the rest are not and require their "extra hardware" which is included in the price. However, note that they DID NOT include the 4 bolts or washers for the front 4 (2 each side) bolt holes. Save yourself a bunch of trips to the hardware store to figure this out - they did not provide this information. They are M10x1.25 bolts and M10 washers. They seem tight going in at first so there may be some threadlock or something at the start of the threads. It'll feel like its the wrong size at first, but 1 full turn with a wrench (can't do by fingers) it breaks through and threads in perfectly.
I did use spray undercoating on the frame where these mount just so there's some seal on the frame where road salt, etc may collect to prevent rusting as much as possible in these areas so I don't have to take these off again for maintenance. Even though I stuffed painters tape in the front bolt holes w/threads, maybe it's possible that some undercoating made its way into the first 2 threads causing the problem above.
These are SOLID installed using their recommendations and hardware. They work great as a step even though they're Trail Editions... just an inch or so higher than the factory running boards. Even with snow/ice on the ground, the powder coating seems to prevent slipping when using as a step, but I did get some grip tape if it becomes a problem.
2025 4runner 6th gen CaliRaised TRAIL EDITION Rock Sliders install on TRD ORP 25739-8e0a0f669c2d979c75c6f0c9276e0e47
2025 4runner 6th gen CaliRaised TRAIL EDITION Rock Sliders install on TRD ORP 25740-1eeeb1aa1a78d87dd4817f5d4d2dd13c
2025 4runner 6th gen CaliRaised TRAIL EDITION Rock Sliders install on TRD ORP 25741-d41f316f163abfb9e8f4d4793cf40fa6
2025 4runner 6th gen CaliRaised TRAIL EDITION Rock Sliders install on TRD ORP 25742-e6dd434d857f157f6b4e58b4a42bcca
2025 4runner 6th gen CaliRaised TRAIL EDITION Rock Sliders install on TRD ORP 25743-ea4d5d873366951f4a2147155fb53c57
Good stuff, Bob. I've got the STEP Edition on the way - shipping in 1.5 to 2 weeks based on email they sent today. Will be looking to sell my factory boards, too.
To be clear on one point: were the necessary M10x1.25 bolts and washers not included? Seems like a mistake on Cali's part. I know that I have the same situation you described: threads only in front two holes on both sides. Expected to get the special "blind" hardware for the other 8 (6 ?) holes on each side but sure would have expected to get the normal bolts for those two threaded holes (which I confirmed exist but are empty).
Thanks for posting. I'll look forward to posting a complete build on my TRD ORP once I get these in and on.
boblupo
boblupo
Robert
You are correct that they DID NOT include those front bolts but agree they should have. So get 4 bolts and washers to be prepared, unless it was just an oversight in my case. And yes it should be 12 total blind bolts and washers (which they DID include)
Mad Ghost
Justin
Wylie Texas
4Runner ORP and Avalon
were you able to install them solo or does it require help?
MartyMcFly
Looks pretty damn sharp!
Out of all the rock sliders sellers, Cali Raised seems to be the most reasonable pricing, free shipping and good quality at ~$1k shipped.. Might have to bit the bullet!
MartyMcFly
Maybe a dumb question: what’s the difference between threaded or unthreaded when ordering?
boblupo
boblupo
Robert
They are referring to your trim level’s frame. The TRD ORP for example only has threads in the front two mounting holes on each side so they will provide blind bolts/anchors for the rest
The free shipping made all the difference. I really wanted to order my sliders from RCI - I slightly preferred the design and they were a bit cheaper. But the shipping charge when I went to order made them several hundred (like $400+) more than the equivalent Cali's with free shipping. The RCI installation manual AND the folks I communicated with were truly great and I regret not giving them my business but as of early November they had not figured out a reasonable shipping method to get the cost down. Frankly, I'm not sure how Cali does it but it sure makes a difference in their sales if I am any evidence.
But I suggest keeping an eye on RCI as an alternative to see if they resolve the shipping issue AND for all you folks above in the mountain states, shipping charges from RCI might not be as prohibitive as they were for me.
For the record, Cali Raised has been great too - very responsive by email. And the manufacturing delay noted on the web site is real - it will be 6 weeks on Monday and I hope to hear soon that they are shipping....
boblupo
boblupo
Robert
The production times were the only downside but they are made to order which is rare I guess. I really like the sleek tucked in look - I almost got the trail edition without the rear kick out thinking it stuck out too far but I’m glad I got the kick out. I can see how on our rocky trails here in CO how it will help guard the rear quarter. And if you put stuff on the roof (skis, camping gear, etc) they will be a big help. They are incredibly solid.
