Will 34” tires fit on 4R TRD OR without a lift or spacers?
Van Solo
Van
Calgary / Canada
Roughly a half inch wider, half inch taller...I think it would rub at full lock, I would worry also about off road articulations. With the full level kit of 2inch front and half inch in the back I think you would be fine. I only have 1.5 inch in the front.
Paek Suspension in my opinion is the way to go.....
https://www.peaksuspension.com/make/toyota/4runner/2025/
Rellims
Sean
ORP - Underground
Not according to our brother Rellims since his was stock wheels and 275 caused issue's
No, got confused, stock of course no rubbing. I upgraded wheels and tires at the same time and it rubbed.
Van Solo
Van
Calgary / Canada
Maximus4R
Adam
Nashville
25 4R ORP
Ahhh. Super helpful, thank you! I worded my question really badly but you answered anyway. I was hoping I could get away with the next size up with a 1.5” lift in the front. I have a set a the TRD Pro rims on the way so guessing I’ll run into running issues similar to yours if I don’t do anything over stock.
Van Solo
Van
Calgary / Canada
Maximus4R
Adam
Nashville
25 4R ORP
I had some 275/70r18 KO3’s put on my ORP with the TRD Pro OEM wheels. No rubbing at all from what I can tell on normal streets or at full lock. It’ll be a few weeks before I can get it on anything besides pavement.
2025 Toyota 4runner Will 34” tires fit on 4R TRD OR without a lift or spacers? IMG_1001
2025 Toyota 4runner Will 34” tires fit on 4R TRD OR without a lift or spacers? IMG_0998
2025 Toyota 4runner Will 34” tires fit on 4R TRD OR without a lift or spacers? IMG_0996
6GRunner
Brian
2024 BMW 230i, 2024 Tesla Model Y, 2020 Jeep Grand Cherokee
Looks great with the TRD Pro wheels! Does it currently have a leveling kit or other lift installed? If so, what did you go with? i apologize if this has already been asked and answered….
Maximus4R
Adam
Nashville
25 4R ORP
Hey! No leveling kit or anything as it sat here with zero rubbing. Unfortunately I had some serious balancing issues with the KO3s. Discount Tire tried to correct but they shook the entire wheel at highway speeds. I have the stock Falkens back on now. They don’t look nearly as aggressive but they aren’t horrible and ride perfectly. I’m going to give the 275/70r18 another shot soon, I just couldn’t keep going back to have them tweaked right now.
2025 Toyota 4runner Will 34” tires fit on 4R TRD OR without a lift or spacers? IMG_1017
2025 Toyota 4runner Will 34” tires fit on 4R TRD OR without a lift or spacers? IMG_1015
2025 Toyota 4runner Will 34” tires fit on 4R TRD OR without a lift or spacers? IMG_1019
k9Hiken
jesse
New Kent Va
2025 SR5
Since the K03 were E load, look at the Toyo AT3 E Load in the 275/70/18. I’m still waiting on my SR5 to show up from the QC hold at port. I picked up a set of the Off-road Two Tone OEM wheels and have a 1.25” Peak Suspension front leveling spacer. I will run either the 275/70/18 or the 265/70/18 Toyo’s depending on the front fender gap and room when I put the spacer on.
TrdProGirl84
2025 Toyota 4Runner TRD Pro
Will 34s fit on a TRD Pro without a lift or any modifications?
