Joestac
Wanted to make a thread on this because I couldn't find any concrete information on the letter swapping process.
My '25 Trailhunter came with the black reflective lettering on from the port and I wanted the bronze, which I ordered from this thread and picked up today from the dealer. LINK
When I popped off the first letter using a heat gun and a plastic pry tool I was surprised to see the letters underneath were already bronze and look much better than the caps as they stand out more. So I am returning the package I just got from Toyota since I never opened them.
You just have to be careful as the bronze letters are stuck with the same 3M tape in the plastic inlet as the overlays are, so when the overlay started warping a bit from the heat I stopped and used the plastic pry. With a little Goo Gone, the bronze letters underneath look great and the tape holding them in place cooled and seems strong as before.
I also ordered the rear letters for the tailgate as they are also black reflective. I got the bronze, but I am a little concerned using the heat gun near that plastic, so I am still deciding if that is worth the trouble.
2025 2026 4runner 6th gen Heritage Grille Letters Color Swap - Black to Bronze (pro tip: just pop off black letter caps) 20251229_131810
2025 2026 4runner 6th gen Heritage Grille Letters Color Swap - Black to Bronze (pro tip: just pop off black letter caps) 20251229_131819
2025 2026 4runner 6th gen Heritage Grille Letters Color Swap - Black to Bronze (pro tip: just pop off black letter caps) 27043-a18216639adb2bba73bbce52e077c122
2025 2026 4runner 6th gen Heritage Grille Letters Color Swap - Black to Bronze (pro tip: just pop off black letter caps) 27044-ae9d988a6aed8e6a60f790333760ac11
MartyMcFly
Wow. Thanks for sharing. They really pop. Looks great!
gmarcucio
Glenn
Upstate New York
Looks good, but I actually want to swap out my Mudbath letters that came on my Pro for black letters.
828findadventure
Tacoma & Tundra
Bronze accents should be legally required on everest, looks soooo good.
I'm thinking of painting my red recovery points bronze to match the grille letters.
J4runner721
Jay
Washington
2025 Toyota 4runner Off-Road, 09 Legacy Spec.B, 2019 Subaru Crosstrek
Thanks for sharing! I love the look for Bronze lettering, my next go-to mod would be Trailhunter grill upper and lower. I'm still debating which lightbar to go with, so much to choose from 🤷‍♂️
Wonder if it's the same for the heritage grille on the Pro? I was thinking about ordering the red and replacing my black. Now I may want to pop these off first to see what's underneath.
Joestac
Joestac
If you plan on ordering new caps anyway it can't hurt to check. I'd be curious too if bronze is the default color.
talmadge
Timothy
SLC, UT
Thank you so much for posting this, my Everest trailhunter also has the black reflective letters, and I’ve wondered from day one if they were just caps over the bronze letters, but was never brave enough to start prying and popping. The bronze letters look so much better, those caps are coming off tomorrow morning.
talmadge
Timothy
SLC, UT
Just as a note to anybody doing this, I discovered the bronze paint on the letters is not very chemically resistant. The solvent I was using to remove the adhesive residue wore through the paint in a couple spots before I realized what was happening and stopped using it. So use something gentle to get it off. Also, the bronze letters are attached to the grille with the same type of adhesive as the caps are to the bronze letters, so it's possible if you're not careful to pull out the entire bronze letter when you're just trying to remove the cap. I wasn't interested in preserving the caps, so I ended up just breaking them off and then heating the adhesive directly with a hairdryer and rolling it off. Looks much better now!
Joestac
Joestac
You can also buy just those bronze letters for under $100 if you damage any of them too bad. They are cheaper than the caps somehow.
SedonaBob
Bob
sedona, AZ
2025 4Runner ORP
I have a TRD ORP that I ordered the heritage grill from a Trail Hunter to replace the stock grill. I want to paint the bronze letters silver as on a pro. Taking the bronze letters off to paint them is one option. If you really can purchase the bronze (in my case silver) letters, that would probably be a lot easier. Do you have a part number for the actual letters?​
