ngfilla94
Nathan
St. Peters, MO
2025 TRD Sport Premium
I've had these parts waiting around for a couple months and I finally had a free day to spend on diving in to this project. If you ever did a grille swap on a 5th gen, throw out everything you know. This requires nearly a full disassembly of the front bumper, so set aside a few hours if you plan on doing this. If you're not handy, this probably isn't a project for you.
2025 2026 4runner 6th gen Trailhunter Heritage Grille Swap + Diode Dynamics Stage Series Lightbar Install - DIY photos & how-to 20251222_092413(1)
There are several videos out there showing how to remove the front bumper (also the easiest part), so I'll skip that. After removing, I set the bumper face down on a moving blanket on top of two sawhorses. You'll definitely want to be able to put it somewhere that's easy to access.
2025 2026 4runner 6th gen Trailhunter Heritage Grille Swap + Diode Dynamics Stage Series Lightbar Install - DIY photos & how-to 20251222_094650(1)
First, remove the active shutters. 6 10mm fasteners. You'll want to fully remove this from the assembly. The clip holding the plug to the assembly is tricky. I ended up mangling mine to get it off after trying to blindly find the hidden release for 5 minutes. The plug itself was unscathed. After fiddling around trying to do the swap in sections, I realized that you need to remove the entire large black assembly. The grille sections are sandwiched between this frame and the bumper cover itself. There are roughly 32 Phillips head screws holding this on, as well as endless clips. Trim removal tools and a small flathead screwdriver are your friends here. I also suggest removing the outer sections of the bumper to make it a little easier to maneuver, it's just a couple extra clips on each side.
2025 2026 4runner 6th gen Trailhunter Heritage Grille Swap + Diode Dynamics Stage Series Lightbar Install - DIY photos & how-to 20251222_095027(1)
2025 2026 4runner 6th gen Trailhunter Heritage Grille Swap + Diode Dynamics Stage Series Lightbar Install - DIY photos & how-to 20251222_102949(1)
Once you tediously work your way around all the clips, you can separate the bumper cover from the inside assembly. Don't forget to disconnect all the sensors before trying to separate everything. You can continue your unclipping journey to separate the grille sections from the assembly. The Diode Dynamics kit provides plug dust covers for the camera plugs since it will be relocated to the upper grille and use a new harness. They also include a new camera bracket.
2025 2026 4runner 6th gen Trailhunter Heritage Grille Swap + Diode Dynamics Stage Series Lightbar Install - DIY photos & how-to 20251222_104532(1)
2025 2026 4runner 6th gen Trailhunter Heritage Grille Swap + Diode Dynamics Stage Series Lightbar Install - DIY photos & how-to 20251222_104542(1)
2025 2026 4runner 6th gen Trailhunter Heritage Grille Swap + Diode Dynamics Stage Series Lightbar Install - DIY photos & how-to 20251222_105232(1)
2025 2026 4runner 6th gen Trailhunter Heritage Grille Swap + Diode Dynamics Stage Series Lightbar Install - DIY photos & how-to 20251222_105217(1)
The TSS module gets relocated to the new lower grille section along with the original cover. Pretty self explanatory there. After you get the camera and sensor swapped over, you can start clipping the new grille sections into place. After you get it all clipped in, you can start getting the inner assembly mated back to the bumper cover and the outer bumper sections if removed. I broke a couple clips during this process, so just take your time and don't rush it back together. Install the new camera harness before reinstalling the shutters. Secure the harness so that it won't interfere with the shutters.
2025 2026 4runner 6th gen Trailhunter Heritage Grille Swap + Diode Dynamics Stage Series Lightbar Install - DIY photos & how-to 20251222_111647(1)
2025 2026 4runner 6th gen Trailhunter Heritage Grille Swap + Diode Dynamics Stage Series Lightbar Install - DIY photos & how-to 20251222_113354(1)
Reinstall all of the silver Phillips head screws. Reconnect all the sensors you previously unplugged. The bracket for the Diode Dynamics bracket screws into factory blank holes in the bumper cover. Install the light bar into the bracket before installing the bracket. It won't fit if you try to install the light bar afterwards. You'll need to clip the zip tie attaching the harness for the TSS sensor before installing the bracket and light bar.
2025 2026 4runner 6th gen Trailhunter Heritage Grille Swap + Diode Dynamics Stage Series Lightbar Install - DIY photos & how-to 20251222_124025(1)
The bolts for the light bar are accessible after the bumper is reinstalled, so don't worry about getting them too snug at this point. I routed the light bar harness along the OEM sensor harness.
2025 2026 4runner 6th gen Trailhunter Heritage Grille Swap + Diode Dynamics Stage Series Lightbar Install - DIY photos & how-to 20251222_124930(1)
It should end up right at the top of the bumper by the camera harness plug. Double check that all your screws are reinstalled and everything is clipped, and you can reinstall the bumper cover. Before fully reinstalling, plug the harness back in and turn the vehicle on to make sure there's no errors from any sensors you may have forgotten to plug back in. If everything checks out, continue to reinstall. If you need to realign the camera, here's the thread detailing how to access the service menu to do so: https://www.4runner6g.com/forum/threads/service-menu-access-procedure-how-to-instructions.7043/
Install the provided harness for the light bar as you see fit. I am personally running OEM style switches from StickerFab for my ditch lights, so I spliced the new harness into what I already had set up.
2025 2026 4runner 6th gen Trailhunter Heritage Grille Swap + Diode Dynamics Stage Series Lightbar Install - DIY photos & how-to DSC_0874
2025 2026 4runner 6th gen Trailhunter Heritage Grille Swap + Diode Dynamics Stage Series Lightbar Install - DIY photos & how-to DSC_0880
2025 2026 4runner 6th gen Trailhunter Heritage Grille Swap + Diode Dynamics Stage Series Lightbar Install - DIY photos & how-to DSC_0868 (1)
2025 2026 4runner 6th gen Trailhunter Heritage Grille Swap + Diode Dynamics Stage Series Lightbar Install - DIY photos & how-to DSC_0882 (1)
2025 2026 4runner 6th gen Trailhunter Heritage Grille Swap + Diode Dynamics Stage Series Lightbar Install - DIY photos & how-to DSC_0891
Overall, this took roughly 5 hours for me from start to finish. If I had to do it again, I could probably shave an hour off knowing what I know now.
Link to the Diode Dynamics kit: https://www.diodedynamics.com/trd-p...filiate_code=ngfilla94&referring_service=link
Grille Part Numbers:
Bronze Heritage Upper 53101-35160
Heritage Lower 53113-35030
Maximus4R
Adam
Nashville
amazing! Looks like the light sits flush with the grille opening, exactly what I was hoping to get with the rave off-road setup. For anyone reading this that wants a flush, oem+ look, do NOT go with the rave kit. Be smart like @ngfilla94, not dumb like me. Also makes me regret getting rid of my white 6th gen… okay, going to go cry in a corner now while I rethink my life choices.
ngfilla94
ngfilla94
Nathan
St. Peters, MO
It sits pretty close to flush. The light bar is slightly larger than the opening so it can't sit fully flush with the front. Not sure how the Rave kit looks but the fit on this is great.
neilkansal
Neil
Kentucky
Thank you for this great write up! Will need to refer back when I do my grille swap
dgorman
Evergreen Colorado
2025 4Runner TRD Premium
I have the rave kit sitting in a box as I haven’t gotten to it, am I going to be disappointed?
Maximus4R
Adam
Nashville
I don’t want to ruin anyone’s Christmas but it was not for me. There’s someone else on here who loves theirs (I think) so maybe I’m just being a Scrooge about it. One thing I have not liked at all has been Rave’s support on the matter.
No pressure, but looks like you’re the tie breaker!
ngfilla94
ngfilla94
Nathan
St. Peters, MO
FWIW, the DD kit is much cheaper as a whole if you opted for the DD light bar. Rave also does not include a camera relocation harness if you have a front facing camera. They want another $170 out of you for that. The DD kit with a sport level light bar is $500. Granted, it does not come with the grille pieces, but those can be had for ~$250 direct from Toyota, and dealers often run discounts. The same setup from Rave with the additional harness will cost you ~$1130 compared to ~$750 from DD and Toyota. Unsure on the price differences across all the different lighting options.
ngfilla94
ngfilla94
Nathan
St. Peters, MO
Uh, looks like I’m missing the required relocation harness? I already have the light bar. Am I missing more stuff given the difference in what you’re quoting on price? I was waiting until a snow day here in Colorado to do the install indoors and haven’t opened it yet.
That's probably about right pricewise since you got a light bar separately. Diode Dynamics is not selling the harness by itself as of right now and I'm not sure if they plan to. They got their first materials delivered for the harness a couple weeks ago, so they're likely going to dedicate current stock to any kits awaiting shipping. If you pieced together the DD bracket ($100) and the grille pieces ($250), the only current option for the standalone harness is still Rave, so you would still end up around $520. I'll check with my contacts and find out if DD plans to sell the harness as separate item.
Edit: No current plans from Diode to sell separately, but they may explore it in the future.
dgorman
Evergreen Colorado
I got in on pre-release so I was in for about $600 w/o BD light as I already have it
Maximus4R
Adam
Nashville
The diode dynamics kit sounds amazing but worst case you can reroute your existing camera cable. It was pretty easy honestly.
I got carried away with mine, I think you really only need to back it up along the blue line.
2025 2026 4runner 6th gen Trailhunter Heritage Grille Swap + Diode Dynamics Stage Series Lightbar Install - DIY photos & how-to IMG_1020
ahenning33
2025 4Runner TRD OR Premium
If you don't mind me asking, what switch are you using? And what did you do about the backlight? I thought about trying to tie into the headlight so the backlight comes on with the headlights, but I hesitate to mess with the OEM wiring.
