deuceduzit
Heads-Up for Anyone Upgrading a Standard Non-JBL Audio System (SR5, TRD Sport non-premium, TRD Off-Road non-premium)
Just finished upgrading the entire sound system in my SR5 (non-JBL), and I wanted to share a few tips that might save others some time and hassle.
Speaker Sizes
Dash Tweeter - 2.75 - 3.5 (I installed a 2.75 but gutting the original tweeter) / Harness - 72-8109
Front Door - 6x9 - Harness - 72-8109 / Bracket - Metra 82-8146 w/ some minor modifications using a drill. 3 out of 4 holes lined up, had to use drill to line up last hole.
Rear Door - 6.5 - Harness - 72-8109 / Bracket - Metra 82-8148 perfect fit.
Brackets / Harness
I had to reorder brackets and speaker harnesses because there wasn’t much reliable info online—I was basically guessing as I went. So if you're planning a similar upgrade, here’s what I did:
  • Replaced all factory speakers
  • Installed an aftermarket amp and subs
If anyone needs help or has questions about parts, wiring, or setup, feel free to reach out. Happy to share what I learned!
Radio speaker output harness (to aftermarket amp or loc) - You can find these at several sites but I bought the Amazon Red Wolf 10 pin one for $14 then used some speed wire to run to amp.
2025 2026 4runner 6th gen Non-JBL Stereo (standard audio system): speaker sizes, speaker harness + bracket info [upgrade info] 1756001383730-png
Current Audio Setup:
  • Amplifier: Kicker LX1200.5 5-channel amp
    (In hindsight, the 7-channel version would’ve been a better fit.)
  • Front + Dash Speakers: Kicker KSS269 component set
    (Planning to replace the dash speakers — they currently sound muddy at higher volumes.)
  • Rear Door Speakers: 6.5" Kicker 51KSC6504 - 2 way speakers
  • Subwoofers: Dual Kicker L7T 12" slim subs
Update 🔧🎶
Audio System Update
• Installed 2x Kicker 47KEYLOCs to defeat the stock head unit’s nasty bass roll-off and overly aggressive factory EQ. The low-end finally breathes like it should—tight, full, and natural.
• Both units are mounted behind the radio, powered via a T-harness sourced from Amazon (seller: AutoHarnessHouse). Not sure if links are allowed here, but feel free to PM me if you want the exact one I used.
2025 2026 4runner 6th gen Non-JBL Stereo (standard audio system): speaker sizes, speaker harness + bracket info [upgrade info] 1757616207012-ao
• Started 3D printing custom tweeter brackets for aftermarket installs. Dash area can comfortably accommodate up to ~4" tweeters now.
If anyone needs help with fitment or wants the STL file for the bracket, feel free to reach out—happy to share!
4running
TX
2020 4Runner SR5
Excellent info and strong first post!! I'd be looking for the non-JBL standard audio system's speaker specs
What components did you upgrade to exactly? - speakers, subs, amps
deuceduzit
Update 🔧🎶
• Installed 2x Kicker 47KEYLOCs to eliminate the dreadful stock head unit bass roll-off and tame the factory EQ. The low-end finally breathes like it should.
Eightonex
Josh
Las vegas
2025 4runner
Awesome post! I’m new to this… how did you wire up the LOC and remote wire?
Im about to wire an lc5i pro. I was just trying to figure out the high level outputs. Im putting in an alpine r-a60f to power some kenwood excelon kfc-xp183c in the front and kenwood excelon kfc-x183 in rear. JP23 to power a 12" sundown sa v2. Like 1300w rms @2ohm and 14.8v. Not really having anything to go off of is a huge pain. I do have a kit for the big 3 and plan on running a high output alternator, maybe 270-300 amps. Im also running 14 gauge ofc copper wire for the door speakers. All the wiring is oxygen free. I ordered Resonix sound deadening. Pretty excited for this build.
NotAhandyMan
chris
north carolina
6th gen 4Runner
Sounds like a awesome build, keep me updated I want to see the final product, I was thinking about doing my door speakers and adding a lci5 in the future, btw I just wired my amp by harness diagram (the one listed above on the first pose)
Gmoney
virginia
Just replaced the front(51KSC6904) and rear(51KSC6504) speakers. I used the harnesses OP mentioned. But I used the brackets from trail grid pro. I also used their video to figure out the disassembly of the front and rear doors.
The OEM head unit is not powerful enough to run aftermarket speakers. They’re clearer but that’s about it. An amplifier seems to be necessary. I’m not sure if I’m going to run a 6 channel to run all 6 or a 4 channel to run the dash (will replace at that time) and front door speakers. Probably the 4channel amp. I will also likely use a mono amp to run a sub separately.
Here are some pictures of the dash speaker (I pulled it up just to see if the SR5 Even came with dash speakers) and an installed 6x9 in the front. I forgot to take more pictures.
2025 2026 4runner 6th gen Non-JBL Stereo (standard audio system): speaker sizes, speaker harness + bracket info [upgrade info] IMG_0182
2025 2026 4runner 6th gen Non-JBL Stereo (standard audio system): speaker sizes, speaker harness + bracket info [upgrade info] IMG_0180
Eightonex
Josh
Las vegas
2025 4runner
Im about done with my build. I got harnesses from taco tunes. The rear doors are done, fronts like 80% done. Whole car is covered in sound deadening except the hatch and the roof. Im doing those in a few weeks. All the wiring is ran for the door speakers, amps and lc, except the grounds on the amps. Got to wire my sub box and make custom mounts for the tweeters in the dash. Ill probably be done in 2-4 more days. I was going to write a build post regarding door speaker sizes, sound dampening, wiring and everything else i had to spend days searching for. I just decided that I dont have the time.
