Help!! Roof rack bolt snapped inside socket housing.
runner_runner
usa
2025 sr5
I was replacing the roof rails on my sr5, to the arb roof rack. Very simple I know. But I got to the last bolt and I broke it off inside the housing. I tried using an extractor kit, but no luck because the housing seems to glide up and down. Anyone know what I can do? I think I need to get into the ceiling of the interior and replace that whole thing. Any have a part number for it? Any help would be thankful.
2025 2026 4runner 6th gen Help!! Roof rack bolt snapped inside socket housing. IMG_1217
shine
Seattle
Not sure how this works on the 6th gen, but on my 4th gen these two bolts would be screwed on to a common backing plate. In other words, if you put a bolt in the other hole you might be able to stabilize the broken bolt enough to start getting it out.
If that doesn't work, $30 on techinfo.toyota.com will show you how to remove the roof headlining assembly in 80 easy steps!
Wish you the best of luck.
watchbuzz
Buzz
East Coast, USA
'25 4runner SR5, '19 Golf R
I read a thread on Reddit a while back and someone had to recover the hardware from the inside. It was a gen5 though.
What I recall was the only partially dropped the headliner to recover the hardware with a magnet.
2025 2026 4runner 6th gen Help!! Roof rack bolt snapped inside socket housing. IMG_8607
Limotint
NY
Not sure if this would be easier than removing the headliner, but if you have access to a welder, you could tack something to the broke bolt and try to back it out again.
watchbuzz
Buzz
East Coast, USA
I’ve always had the best lock tapping into bolts with a metal bit and a reverse threaded bolt (it gets snug and the broken bolt gets loose).
In this situation I’d be so worried about the roof integrity… I’d likely focus on pulling the headliner and advancing the hardware from the inside.
Such a bummer.
runner_runner
usa
2025 sr5
Thanks guys. I was able to find the part. And I could easily slip my hand into the headliner to replace it. So it wasn’t as hard as I thought it would be. Just waiting on the part now.
shine
Seattle
That's great! post a picture of what it looks like!
