TXPanhandle
TX
2025 SR5 4x4
I might be open to letting someone have mine, especially if the removal is clean
Mad Ghost
Wylie Texas
4Runner ORP and Avalon
I'd be interested, I had toyota not install mine because I felt I could get a better deal and am looking for someone like you or maybe a different brand.
dirtwheeler
dirtwheeler
Do you feel like it hampers your line of sight? When I look at stoplights, etc, it blocks things.
Starting to think about removing it
I haven't noticed it blocking my view. Might be a difference in our height and/or seat position. It might be possible to mount it on the other side of the mirror (just thought of this but haven't checked)
dirtwheeler
dirtwheeler
Removal should be straightforward. I'd carefully use a heat gun from the front of the windshield to help get the adhesive off, then clean with goo gone. The rest is just installation in reverse. I wouldn't let anyone do it unless I knew that they knew what they were doing. The Toyota dealership would probably just charge their hourly rate to remove it. It's a half hour job tops, but they will probably charge you an hour
oldskul08
2025 TOYOTA 4RUNNER
how you guys connect the dash cam to your phone app? I'm having trouble adding it to the toyota dash ap. I already delete and reinstall the app and even forget the "integrated toyota wi-fi" and still couldn't add the dash. It's says "no internet connection" below the "toyota wi-fi". anyone having a hard time connecting/adding?
YoMike
Michael
Anaheim
Watching this because I’m trying to figure it out too
chuck101
Va
6th Gen 4runner
Anybody have a copy of the installation instructions?
dylanst0kes
Dylan
2025 TRD Sport Premium 4Runner
After you took off the light console, was there just a plug? I’m planning to buy an aftermarket cam but I want to make sure I understand what I’m getting myself into when it comes to wiring
don_king
tyler
iowa
2025 4runner TRD pro
Can anyone post the link how to set this thing up? I can’t find it in the manual!
btgood1
BT
NOVA
2025 SR5 / 1999 SR5
Can't find the manual either. I asked the parts department to print it out for me, which they did. I bet if you call they will email it to you.
Toyota Integrated Dashcam Manual
From https://www.toyota.com/owners/dashcam/
Note that there are separate manuals for installation, quick start, and viewer, but this one covers the use of the software reasonably well. (If you are looking for install manual, hunt on the part number PT949-34222 (Dashcam)- the 2024 tacoma install manual works exactly for 6G 4Runner. Only small difference I could find is the mounting direction of the prewired jack is easier reversed on 4Runner - making it easier to connect.
I'm struggling with 128 GB card - starts beeping wildly before I have a chance to connect and format it (I know it needs to be formatted FAT32 and am experimenting with different format settings - not successful the first 2 times.) Advice welcome.
ALSO - does anyone else have the "dome" lights (in the roof map light console and over the back seat) stay on all the time after installation? I'm going to try disconnecting the battery and the map light console connector and dashcam connecter and reconnecting (per the install instructions) to see if the lights go off, but wondering if anyone else has had this issue.
Dead Horse
Oklahoma
Those things are triple the price of a comparable Viofo/Garmin/etc.
But having it come from Toyota and be a supported thing is probably worth it to a lot of folks.
ALLLL of them with wifi that I've messed with have had some pretty mediocre apps. Middling at best. Most of them are straight trash. I have a Viofo and the wifi connection does buggy shit with either bluetooth or Android Auto...I can't remember which. I remember it being something I had to fiddle with more than I should have to get the wifi to connect and pull the video to my phone. So that might not be just a Toyota thing.
Nice writeup!
Circling back around to my own comment on this from months ago.
Yeah. I was wrong. Toyota's software for this dashcam is by FAR the worst I've experienced. It is absolute garbage. I was ready to throw it all in the trash last night when I tried to set it up.
dirtwheeler
dirtwheeler
I haven't had any issues with it, but I usually don't use the software. Once I got it setup the way I want, I just pull the SD card if I ever want the footage off it. The camera app software did seem a little clunky. I've got some aftermarket cams on my other vehicles that were cheaper and work fine too. I'm not sure if how you could use the OEM wiring harness with an aftermarket cam, but I'm sure it's possible.
My only minor gripe is that the g-sensor (if that's what it's called) is a little too sensitive. It gets engaged on pretty small bumps (beeps and holds onto the recording longer). Eventually I'll try to change the sensitivity.
Hope you got through the setup OK!
Dead Horse
Oklahoma
I've set up several others of varying brands. Most of them are pretty bad, but Toyota's software/documentation is far and away the clear loser LOL. Viofo was the most painless so far. I have that in my Tunda and my wife's car. I'll likely pull the one from my Tundra and put it in my 4Runner. Or maybe the FITCAMX. I like how it doesn't attach to the windshield. Biggest gripe with the Viofo is when the wipers skip/go BRRRRT, it saves and protects the video. Pretty sure all cameras can be falsely triggered by things like that though.
dirtwheeler
dirtwheeler
The last one I got is the rove r2-4k pro for my Jeep earlier this year. I've been pretty happy with that one but wiring it in was a lot more work the the OEM 4Runner cam with its wiring harness already setup
