ZekZoop Hood Insulation Mat - Install Feedback
The following are my personal observations after buying the @Zekzoop Hood Mat. Against my better judgment, I went with an aftermarket product over OEM. I found it on Amazon with a discount resulting in a final price of $59.99 plus sales tax. I received the product today shipped UPS. It was folded in the middle to get in a reasonable sized box. I apologize up front for not taking pictures.
The box had the folder pad, 15 pushpin rivets, and a single sheet of paper with list of contents, picture and YouTube link (not seen until I finished the install).
I just watched the YouTube video
and noticed a few things. It has two people which would have been helpful. He covered the engine bay with a mat, presumably to prevent dropped pins. The pins do not align as easily as shown in the video. They are a real pain to install. I saw a roll of masking tape but no indication if it was used. Also, the last pin in the center-Rear of the hood was very difficult unless you have very long arms.
The mat is not too bad, not sure how durable it will be going forward. I also do not know if it's fire/heat resistant. I doubt Toyota would cover a warranty claim on fire if they saw the mat installed.
The push-pins are very low end and nothing like the function of the Toyota push-pins. I will probably replace but wait a few weeks to see if the current pins hold up. Unlike some push-pins that are just holding something in place, these have the weight of the may and have to deal with the bumps of the road.
If you're installing, get a helper with long arms. I had to climb in the front with 2/3rds of me in the engine bay to get the last push pin. Note - None of them aligned with the holes. All slow but you had to push up and move pad around to get the alignment.
A suggestion for the manufacturer would be different pins and ones that attach to the mat so when you hold the mat up, the push-pin is solid in the mat and you just need to push into the hold and lock.
I may install with a non-push-pin solution. You can get nylon liners or receivers for the holes and then use screws and large black washers. A much stronger fixing.
I hope this helps.....
paradizecityz
Houston, TX
I also recently got the same mat but all the holes lined up perfectly for me, I didn't have any issues. 2 people would be nice but I did it by myself. I did buy "better" pins to use as well.
df525
2025 4 runner sr5
is the engine noise anymore quieter after you installed it?
HVLA
Lexus
Trapping additional heat in the engine bay of a forced induction motor probably isnt something I would want to be doing.
Cruise
Cruise
Denver, CO
2025 4runner, 2009 Duramax, 1992 Ranger
Your ORP model should have a very similar under hood insulator pad from the factory. SR5 models do not come with it.
Cruise
Cruise
Denver, CO
I ordered and installed the same insulator pad. No issues or complaints with my install.
Engine/turbo noise seems ever so slightly quieter, but it's probably just a placebo effect. I do have ESE (Engine Sound Enhancement) disabled as well.
LARIN
Stitch@317
2025 Toyota 4runner SR5
Does it improve highway noise ?. Sounds like it does do much for engine noise from what you stated
Cruise
Cruise
Denver, CO
It's not my daily driver, it's my wife's. Originally she had complaints about the engine and turbo being noisy when we first got it. After disabling ESE and installing the hood insulator she says it is much quieter.
The hood insulator is only about 1/8 inch thick at most of carpet like material. My opinion is that it can't make that big of difference, but it does make the under hood look complete like it should have come from the factory.
Not driven it yet and being honest, my hearing is not up to par. I think it will help creating an air gap between the upper engine and hood. I wonder if it would help in the hood flutter at speed on the highway... Need to test soon.
The hood pad is not bad quality. It's just the installation for some will be a pain. The hood push-pins do not seem good and I am replacing with Toyota type as they seem much higher quality. In doing my test fit of an existing Toyota push-pin, I found it hard to get the hood pad supplied pins out. Therefore, they might stay in place for longer that thought. Of course, heat and vibration will stress them.
Part of my purchase decision was the look of the hood. All that nakedness was bugging me. When fitted, it does look okay. A few gaps in places that Toyota does not have a hole and the molding is not strong enough to keep some edges form fitting.
Yes, many of the holes did not line up but all can be worked through.
All in all, its a good product so far.
df525
2025 4 runner sr5
I just installed it on my SR5. It appeared to be pretty good. 2 installation tips.
1. apply the push pins from one side of the hood to the other so you can see the holes.
2. get a small screw driver or probe to find the holes on the hood. so you get an idea about the angle to push those pins.
Hard to tell the effect. I "think" engine noise appear to be better during idle.
I replaced all “clips” with made in Japan OEM. Cost be over $3 each which is a rip but, they are good and can be removed with a push.
