T4R_Pro
Los Angeles, CA
These have been sitting for a few weeks in the garage, and since Socal weather wasn’t too shabby today, i decided to install them. The mud flap install seriously took longer than the running boards.. Lol.
If i had to do it again, i’d probably just get the Ark Mini mudflaps, but overall, im happy with how it turned out.
Install time for everything was around 2.5 hours by myself.. i was taking my time and had a couple beers as well.
OEM TRD Running Board Part Number: PT767-89250
2025 2026 4runner 6th gen Ark Mudflaps & OEM TRD Running Board Install on 2025 4Runner TRD Pro 6th Gen Ark Mid Mud Flaps & OEM TRD Running Board Install on TRD Pro 9
2025 2026 4runner 6th gen Ark Mudflaps & OEM TRD Running Board Install on 2025 4Runner TRD Pro 6th Gen Ark Mid Mud Flaps & OEM TRD Running Board Install on TRD Pro 1
2025 2026 4runner 6th gen Ark Mudflaps & OEM TRD Running Board Install on 2025 4Runner TRD Pro 6th Gen Ark Mid Mud Flaps & OEM TRD Running Board Install on TRD Pro 2
2025 2026 4runner 6th gen Ark Mudflaps & OEM TRD Running Board Install on 2025 4Runner TRD Pro 6th Gen Ark Mid Mud Flaps & OEM TRD Running Board Install on TRD Pro 3
2025 2026 4runner 6th gen Ark Mudflaps & OEM TRD Running Board Install on 2025 4Runner TRD Pro 6th Gen Ark Mid Mud Flaps & OEM TRD Running Board Install on TRD Pro 4
2025 2026 4runner 6th gen Ark Mudflaps & OEM TRD Running Board Install on 2025 4Runner TRD Pro 6th Gen Ark Mid Mud Flaps & OEM TRD Running Board Install on TRD Pro 5
2025 2026 4runner 6th gen Ark Mudflaps & OEM TRD Running Board Install on 2025 4Runner TRD Pro 6th Gen Ark Mid Mud Flaps & OEM TRD Running Board Install on TRD Pro 7
2025 2026 4runner 6th gen Ark Mudflaps & OEM TRD Running Board Install on 2025 4Runner TRD Pro 6th Gen Ark Mid Mud Flaps & OEM TRD Running Board Install on TRD Pro 8
2025 2026 4runner 6th gen Ark Mudflaps & OEM TRD Running Board Install on 2025 4Runner TRD Pro 6th Gen Ark Mid Mud Flaps & OEM TRD Running Board Install on TRD Pro 6
4RunnerTony
Tony
Venice Florida
Are the mud flaps no drilling required and what is the price?
Has anyone used the micro's, I'm looking for one's that can be used offroad but not sure how good that's gonna work with road grit flying up and the mid's look about what I got.
OEM drug against everything, they bent, twisted and then went back into shape but it beat the crap out of the bottom edge. Now I take them off when I hit the trails but that's a pain.
James Cole
MX
Badlands Sasquatch (hopefully)
Do these require drilling? Site is not clear…
zgreen
Zach
There front does not require drilling, but the back ones do. It's two small holes through the wheel well lining, so two attachment clips can go through.
3RIV1
Travis
Tri-Cities WA
If i had to do it again, i’d probably just get the Ark Mini, but overall, im happy with how it turned out.
Running Board: PT767-89250
View attachment 16198 View attachment 16199 View attachment 16200 View attachment 16201 View attachment 16202 View attachment 16203 View attachment 16204 View attachment 16205 View attachment 16206
3RIV1
Travis
Tri-Cities WA
Thanks! Just took delivery of my TRD Pro as well and am going to order the mini's! Appreciate the link! Yours look great!
If you mean the micros, take a pic when you get them installed please.
3RIV1
Travis
Tri-Cities WA
Yes, that's what I meant :) I have OEM running boards ordered too and I am going to take pictures of the entire vehicle and post with everything added.
Hypnosis4u2nv
Paul
Florida
I just installed mine. Took about an hour to do all four. Once you get one of the front an rear on, then you can do the other side of the truck with no issues.
The rear flaps have 3 holes (identified as the yellow dots in the attached diagram) that don't go into anything (at least for those that don't come with the OEM flaps already installed). I didn't drill any new holes during my install as it would require removing the tires. It seems secure enough but I'll take it for a spin and if any issues, I'll report back.
As mentioned, the supplied screws are longer and use a machine thread versus the OEM coarse threads. I did run into a problem with the supplied screw in the inner wheel well area when it came to tightening it. It didn't tighten all the way and required me to reach behind with some pliers to hold down the plastic nut in order to tighten it down snug without the required washer spinning freely.
Attached is install diagram for use with the included hardware that would work for micro, mid and regular flaps.
2025 2026 4runner 6th gen Ark Mudflaps & OEM TRD Running Board Install on 2025 4Runner TRD Pro 6th Gen Screenshot_20250729-130210
timelapse
ATL
2025 ORP
Looks good. These are the mid-length Ark flaps? I've been having issues with the OEM Toyota mud flaps. Still managing to shoot gravel into my door panels and even up to the roof (4 times so far!). I assume it's the result of the wheels being turned and perhaps no mud flap will truly reduce this. Stock TRD ORP wheels with +55 offset, so they're tucked into the fender for the most part.
timelapse
ATL
2025 ORP
I did get the full sized ones though.
Got any better pics, maybe from the side with a wider shot? Trying to decide between mid and full. Full looks a bit lower than stock Toyota mud guards. A bit of a concern off road since the Ark's are only slightly bendable.
