Replace OEM inverter?
dgorman
Evergreen Colorado
2025 4Runner TRD Premium
Since we all know the stock inverter is essentially garbage, I thought about replacing it with something from victron or red arc. Does anyone know where the stock inverter is located?
CMill4Runner
Craig
CO
I hope it's not garbage this was the reason I bought a Hybrid so I can recharge my Ecoflow camping!
Mad Ghost
Wylie Texas
4Runner ORP and Avalon
My guess is he's not happy it only puts out 100w while in drive.
DustyLens
Dusty
Phoenix,AZ
2010 4Runner SR5
Possibly, but, if so, that's not a failing of the inverter itself. I blame the lawyers. :)
It occurred to me, that I could keep a power supply in the car to have more power while driving, if there's a need. There's been no need so far.
dgorman
Evergreen Colorado
It’s garbage because it’s a modified or square sine wave. Many electronics don’t work with that and need a pure sine wave.
dgorman
Evergreen Colorado
Ecoflow batteries won’t work (delta 2 for example)
kzrman
Maine
2025 Trailhunter
How do you know that it's a square wave?
dgorman
Evergreen Colorado
While I haven’t tested it with an olliscope, it’s known that Ecoflow batteries won’t work (or well) with non-pure sine wave inverters. Dometic fridges will, however it’s not great for the electronics. I plugged my d2 into the 120V port. Set it at 200W (well below 400W max), turned on the upfitter switch and will not charge with car running.
Take it to house outlet and charges just fine. My ram truck is the same way, cheap non-pure sine wave inverter and similar results with various electronics .
If this is working for others on their 6g4r I’d be super curious - there’s another thread on this in this forum
Iirc too.
CMill4Runner
Craig
CO
Iirc too.
Since he shows it working in this video either Toyota made a change or Ecoflow??
kzrman
Maine
2025 Trailhunter
Also keep in mind that for the LC250 Toyota could be using a different model inverter. This is not likely, but is possible.
Where's an O-Scope when you need one?!
