Accessories/mounts that work with Trailhunter ARB roof rack
Jeff
Nevada
2025 4runner Trailhunter
I just got a trailhunter and love it. I was curious about the roof rack and mounting to it. The only other roof rack I've had was a Yakima Load Warrior Basket. Easy to use and pretty universal.
The ARB is really nice, but also a lot different from what I'm used to. What type of mounts would I use with the ARB? I see a fair amount of accessories on the ARB site, but not entirely sure what would fit my rack and what wouldn't. (Are there any other manufacturers that are making things that would be compatible with the ARB rack?)
Thanks!
2025 2026 4runner 6th gen Accessories/mounts that work with Trailhunter ARB roof rack c4a644d7-6eec-4af1-bb96-ef6aad94b5c1
2025 2026 4runner 6th gen Accessories/mounts that work with Trailhunter ARB roof rack 7ee48d60-e295-4ab9-874a-14ce46a0e101
Grumpdog
Washington State
2025 4runner
Got a reply from ARB. So ARB's Dovetail on the outside of the crossbars, and T-channel accessories should be compatible in the middle.
Snackman
Ben
I bought the ARB base rack propane bottle holder, base rack ratchet strap set, and the 4 piece eyebolt tie down set on Amazon. These accessories worked great with the factory rack. 11 lb. propane bottle is in front of the left tub.
Thanks for posting these pics! TBH the setup was a little confusing for me at first with how the anchors are supposed to work, but I see it now.
Looks like that dovetail setup can work on any cross bar as well as the outside of the rack which is really nice!
Im going to order some of those tie down kits or sure, thanks again!
Snackman
Ben
Do you know if those T channel pieces are designed to fit the slots in the crossbars? Having a hard time finding anything actually mounted up to them. All of ARB's pics seem to show stufff strapped to the dovetail.
THanks!
Grumpdog
Washington State
2025 4runner
The dovetail
THanks!
ARB sells quick release pins for recovery boards that are t-slot. The cool thing about Amazon is, order it and see if they work. If not, send it back. I'm going to order some of the load stop t slot for crossbars.
Everybodyduck
Michael
2025 4Runner I-Force Max
I'm late to this thread, but I spoke with ARB, and they confirmed their dovetail accessories are compatible with this roof rack made exclusively for Toyota. They confirmed that Thule's t-slot system and other T-slot brands are also compatible with this new roof rack. That's a good thing.
Grumpdog
Washington State
2025 4runner
Tamer1122
Sacramento, CA
Just got a Trail Hunter roof rack. Question, does the four corner carrier legs have like a rubber gasket/ weather seal under the base of four legs carrying the rack. My car is a TRD Sport.
Icculus
Adam
NC
2025 IC Trailhunter
Watching this thread as well. While interested in things for the "top" I'm currently more looking for light brackets that would work to attach lights to the back of the rack
Jeff
Pennsylvania
2025 4Runner Trailhunter | Underground
Do you know if you can mount exterior molle panels to the ARB 3/4? I'd like to hang a gas can on the side. I rather not put it flat on top since it could start leaking being flat
hussch85
Hussein
Cypress, CA
2025 4runner Limited Hybrid
I would like to know this as well. Or if any particular molle will work without drilling
