Toyota OEM Dash Cam - placement correct?
MPS
milo
canada
Hi Guys. Can I get your opinion on the placement of the Dash Cam Installed by my local Toyota Dealer. I find it to be out of place. I was expecting it to be installed closer to the back of the rear view mirror where it will be more out of sight. Thanks!
2025 2026 4runner 6th gen Toyota OEM Dash Cam - placement correct? IMG_5135
MPS
MPS
milo
canada
Thanks. Ill go back and will ask them to reinstall.
zgreen
Zach
Is that the Toyota dash Cam? It looks a lot different from the one that was port installed. And yes, it isn’t even close to being in the correct potions. Mine is snug up close to the mirror on the driver side. Good luck!
Hacksaw
az
2025 4runner TRD-ORP
Like zgreen said, it doesn't look like the standard toyota dash cam. Can you post what the make/model of the dash cam is? That's a truly bizarre "middle of nowhere" place to mount it, but maybe there are buttons or SD slot on the side and you wouldn't be able to easily press/see the buttons without it being so far to the right. Also, depending where the lens is, if you wanted to leave it on the passenger side, it's possible it could be moved higher as long as the lens isn't looking thru the dot grid on the windshield.
Note that while most people don't bother looking up laws on dash cam placement, there are some weird and very constraining ones in some places. Given the fairly large size of this one, maybe in your location the law says it has to be to the right of center because it would obstruct view too much on the left?
MPS
MPS
milo
canada
It
it is actually from a Toyota Dealership here in British Columbia Canada. Ill post a photo of the Unit
2025 2026 4runner 6th gen Toyota OEM Dash Cam - placement correct? IMG_5141
MPS
MPS
milo
canada
It is from a Toyota Dealership in BC, Canada. The Service advisor gave a photo of what is supposed to be a guideline from Toyota on How to install the Camera. The point I made
To the dealership was I was expecting my camera to get installed the was Toyota Advertised it on their website. Not to be installed pratically directly in front of rhe passengers line of sight. Ill send photo of the installation instructions as well as what I thought it would look like.
2025 2026 4runner 6th gen Toyota OEM Dash Cam - placement correct? IMG_5156
2025 2026 4runner 6th gen Toyota OEM Dash Cam - placement correct? IMG_5155
2025 2026 4runner 6th gen Toyota OEM Dash Cam - placement correct? IMG_5137
2025 2026 4runner 6th gen Toyota OEM Dash Cam - placement correct? IMG_5136
2025 2026 4runner 6th gen Toyota OEM Dash Cam - placement correct? IMG_5140
zgreen
Zach
Per your pictures above, they gave you the old model from 2023. The two pics from the bottom, where the unit has the red “action” button, that is the latest model and where it should be mounted. It looks like the dealer was maybe trying to slip by the older model on you….
Hacksaw
az
I looked up the FCC ID. That dashcam is from late 2016. They're trying to pull a fast one. A person probably couldn't get $50 for that dashcam on ebay even if it were unopened in its original box. Dashcams have advanced significantly since then.
Vincenzo
Southeast
Even if this a new version. Yours is not in the same position as the one in the instructions. Can you show the work order so we can see the part number
MPS
MPS
milo
canada
Thanks for the info. I will be speaking with the dealership tomorrow and have this rectified.
Thanks a million. Thisnwill
Hello Vincenzo. Here’s the work order.
2025 2026 4runner 6th gen Toyota OEM Dash Cam - placement correct? IMG_5162
zgreen
Zach
That was expensive for the old unit. The brand new one was $499, port installed on mine, and I feel like I overpaid for what it was. There are plenty of really fantastic aftermarket options out there, that are more robust than the Toyota offerings...
  • Like
Reactions: MPS
Dphotos
Dale
Website
www.daleberman.com
1997 Toyota 4Runner Limited
You need to sit down with The dealers general manager and tell him or her you are not happy about being sold an older model dash cam for a new 4 Runner. The dealer needs to make this right for you. I hope they fix the issue. I would also send a letter to Toyota to describe what happened. I hope there is another Toyota dealership close by because if this was me I would have lost confidence in this dealership to do any kind of warranty repairs.
Dphotos
Dale
Website
www.daleberman.com
I have lived with the front dash cam for a few months now with my Limited and I hate it. It is in my line of site and it really bothers me. I will be looking for a replacement cam that will install behind the rear view mirror and I would like to get a rear dash came too.
