Roof Rack - ARB Platform 3/4 Length [Confirmed: same as Trailhunter roof rack]
dirtwheeler
dirtwheeler
The weight ratings are likely due to the stated ROOF capacity of the vehicle, not necessarily the rack. Be careful overloading your rigs!
Where do you see the roof capacity stated? I'll look in the manual later but I didn't trip across this before.
Hacksaw
az
2025 4runner TRD-ORP
Ah! I think you're right about that. When I google "2025 4runner roof load rating" it says 165 lbs dynamic. And I presume you have to subtract the weight of the rack from that. So my thought of using the roof of the 4runner with a 6' length rack as a semi-substitute for a pickup bed is probably a pipe dream. I could probably barely carry 100lbs before reaching the roof limit. Am I looking at that correctly?
Edit to add, @Rellims above, found 135 lbs listed in the manual so that's probably more official than my google search results. And even worse.
Edit #2: when I look at the Prinsu Pro website for the 2025 4runner full-length rack (they don't give the weight of the rack itself), they strongly imply the 1200lb static strength of their rack itself overcomes the roof limit. Are they right, or are they using dangerous "marketing speak." If the roof itself cannot be reinforced by the construction of the rack, there's no point spending money on any rack with more that ~150 lbs static.
Hacksaw
az
I just want to confirm the 135 lb number Rellims gave above. From p204 of the manual:
"4WD models: Do not exceed
135 lb. (62 kg) cargo weight on
the roof luggage carrier. Place
the cargo so that its weight is
distributed evenly between both
cross rails."
I wonder if Toyota's determination of 135 lbs has more to do with changing the center of gravity of the vehicle with the top-heavy weight, and the vehicle becomes progressively more unstable as more weight above that amount is added to the roof when cornering (or swerve to avoid hitting something), more than it has to do with the strength of the roof (which, after all, doesn't flatten into a pancake after a rollover accident).
spyder40
Indiana
2021 4Runner ORP
cross rails."
My take is that's the limit on the stock rails and crossbars which are pretty weak. I have a Sherpa on my 2021 and it definitely can handle more than that. The bolts and mounting on the 4Runner are pretty stout built.
DTMorris007
Devin
Central Kentucky
2022 Toyota Tacoma Trail Edition (2025 TRD ORP On Order)
Are the cross rails adjustable to move front and back? I’m looking to fit 95L roam cases and what is the dimensions of the rack too
thank you
I've been wondering the same thing about the OEM crossbars but haven't been able to find anything definitive online. They look like they might be adjustable but also every single one I've seen with the OEM crossbars have had the bars in the exact same place...
Rellims
Sean
ORP - Underground
thank you
Missed this, sorry. No the rails do not move and the dimensions are 41"x52"
DTMorris007
Devin
Central Kentucky
What everyone's opinion on wind noise? Ive been looking around in the forums and haven't found much
Snackman
Ben
Im wondering if anyone has found a good mounting option for this for traction boards? Seems like anything thats a "Prinsu style" mount would work the same on this, but wanted to confirm before ordering anything.
Personally wish that this was a full length one, might end up ordering one down the road. Great for now though, just offset's the rod vault on top a little more than im comfortable with.
nubsors
This is accurate. The owners manual for the Trailhunter clearly distinguishes between the standard roof rack and the ARB rack that comes with the Trailhunter trim.
2025 2026 4runner 6th gen Roof Rack - ARB Platform 3/4 Length [Confirmed: same as Trailhunter roof rack] Screenshot_20250831-081215
generic.user
Toronto
BMW i4, Lexus NX
Isn't the Trailhunter's lack of moonroof supposedly for higher roof weight capacity? yet it's the same as the TRD Pro, which does have a moonroof...
