Ceiling Pod / Map Light Console Removal?
Kokorone
Gabriel
Laguna Hills, California
2025 4Runner SR5 4WD
Anyone know the secret to removing this pod in the ceiling so I can install a dash cam? I’ve checked how it’s supposed to be removed on the 2024 Tacoma, quite literally just pulling with two hands from the front and it flat out doesn’t work here.
I’ve been pulling on this with various tools, tape, and even a screwdriver and it hasn’t budged.
Going to lose my mind over this since I need to pull it down to install this dash cam.
2025 2026 4runner 6th gen Ceiling Pod / Map Light Console Removal? IMG_1110
Gastan
Tacoma TRD Pro
Just gotta pull hard on the map light console!. This is from a dashcam DIY from a 2024 Tacoma owner:
The most scary part of the process for the new truck is tearing out the top Map Light Console. The first time you take it off will take a lot of force and it seems like something might break, but it won't there are 4 red snap clips holding it in. pull the edge that's closest to the windshield off first, then the back. You also need to pull the visor clip out. You only have to turn it counterclockwise back to 10 o-clock then can pull it out.
2025 2026 4runner 6th gen Ceiling Pod / Map Light Console Removal? 1730506571753-sg-jpg
2025 2026 4runner 6th gen Ceiling Pod / Map Light Console Removal? 1730506586063-4l-jpg
Source:​
@Kokorone Since you're doing a dashcam install on the 2025 4Runner right now, maybe you can writeup a DIY guide for us 6th gen 4Runner owners as well?
Jetsareus
Joe
Pacific Northwest
First 4Runner
I am going to get power from there as well for my Garmin Mini. Please share what you find up there, -like constant +12v and acc +12v.
If you end up snapping off anything, a heads-up would be appreciated. After the swearing…?
Gastan
Tacoma TRD Pro
I posted the answer right before you replied (right above your post). Just have to pull hard on the map light console to remove it.
Kokorone
Kokorone
Gabriel
Yeah I read that thread before attempting this. I’m not sure if the 4Runner just has a different setup but I was yanking on it hard enough to actually start disassembling the ceiling pod trim but it didn’t remove it. Tried again with me and my wife both pulling as hard as we could and no go.
Jetsareus
Joe
Pacific Northwest
First 4Runner
Thanks for your info and the thread link. It answered the power available question I had as well. Pretty good of Toyota to put a provisional connector up there!
ryno
ryno
sw. mo
25 4 runner
so what was the out come here?
Jpr18
Southern California
You don't need to remove the overhead console to install the Dongar with the auto-dimming rearview mirror. OP bought the wrong connector.
Kokorone
Kokorone
Gabriel
The SR5 and multiple other trims do not have the auto dimming mirror. I had to use the ceiling pod harness for this.
Jpr18
Southern California
Ah my bad, I saw the chunky sensor surround on the mirror and assumed it was auto dimming.
Kokorone
Kokorone
Gabriel
Hacksaw
az
2025 4runner TRD-ORP
Source:​
Why does the visor clip need to be removed for the map lite panel to come out? Looks unrelated but there must be a reason.
Kokorone
Kokorone
Gabriel
It doesn’t. I’d recommend doing it though since it’s tough to get the headliner to pull down enough to route cables to the windshield without removing.
