Do SR5 wheels fit 33" tire (i.e. 285/70R17) or what's largest size? Do 2025 TRD Pro wheels fit without modifications?
Chcg12
Don
Pc0j224
2021 trd pro
Question does anyone know if the SR5 with 17" inch wheels would accept an aftermarket 33" inch tire with no modifications?
Also, would the 18 inch rims/33 inch tires from the 2025 TRD Pro fit on a regular SR5 with no modifications? Thanks.
Gastan
Tacoma TRD Pro
You can fit 33's on factory SR5 17" wheels.
Here's two examples of 33" tires on stock SR5 wheels on 2024 Tacomas (same fitment as 2025 4Runner) without modifications and no rubbing:
285/70R17 BFG KO3 tires (source)
2025 2026 4runner 6th gen Do SR5 wheels fit 33" tire (i.e. 285/70R17) or what's largest size? Do 2025 TRD Pro wheels fit without modifications? 33's 33%22 inch tires 285:70R17 KO3 tires on SR5 wheels 2
2025 2026 4runner 6th gen Do SR5 wheels fit 33" tire (i.e. 285/70R17) or what's largest size? Do 2025 TRD Pro wheels fit without modifications? 33's 33%22 inch tires 285:70R17 KO3 tires on SR5 wheels 1
2025 2026 4runner 6th gen Do SR5 wheels fit 33" tire (i.e. 285/70R17) or what's largest size? Do 2025 TRD Pro wheels fit without modifications? 33's 33%22 inch tires 285:70R17 KO3 tires on SR5 wheels 3
285/70R17 Firestone Destination X/T tires (source)
2025 2026 4runner 6th gen Do SR5 wheels fit 33" tire (i.e. 285/70R17) or what's largest size? Do 2025 TRD Pro wheels fit without modifications? 33's 33%22 inch tires 285:70R17 tires (Firestone Destination X:T on SR5 wheels 1
2025 2026 4runner 6th gen Do SR5 wheels fit 33" tire (i.e. 285/70R17) or what's largest size? Do 2025 TRD Pro wheels fit without modifications? 33's 33%22 inch tires 285:70R17 tires (Firestone Destination X:T on SR5 wheels 2
KTRAN
Kevin
Bay Area CA
4R
33's 33%22 inch tires 285:70R17 KO3 tires on SR5 wheels 2.jpg's 33%22 inch tires 285:70R17 KO3 tires on SR5 wheels 2.jpg
33's 33%22 inch tires 285:70R17 KO3 tires on SR5 wheels 1.jpg's 33%22 inch tires 285:70R17 KO3 tires on SR5 wheels 1.jpg
33's 33%22 inch tires 285:70R17 KO3 tires on SR5 wheels 3.jpg's 33%22 inch tires 285:70R17 KO3 tires on SR5 wheels 3.jpg
33's 33%22 inch tires 285:70R17 tires (Firestone Destination X:T on SR5 wheels 1.jpeg's 33%22 inch tires 285:70R17 tires (Firestone Destination X:T on SR5 wheels 1.jpeg
33's 33%22 inch tires 285:70R17 tires (Firestone Destination X:T on SR5 wheels 2.jpeg's 33%22 inch tires 285:70R17 tires (Firestone Destination X:T on SR5 wheels 2.jpeg
Thanks so helpful to know for my incoming SR5.
Those 33" KO3s upgrade the SR5's look instantly! ?
risurfstyle
James
New England
2025 SR5
I'm looking to increase the tire diameter on my SR5 2025 - my goal is to have a more rugged aesthetic tire plus slightly larger diameter/height tires - considering the Falken Wildpeaks.
When I spoke to Toyota parts dept. they basically said I can't increase diameter, at least not according to their "official" requirements of what they are allowed to recommend. It will result in the speedometer being slightly off, but does anyone know if there are other issues, or if the warranty is voided by going to a larger tire?
From my research I am interested in going from the 30.5" diameter OEM tires to around 32". When I use www.tiresize.com and compare here are the results, which gives a pretty significant speedometer error. Who has experience with this to put my mind at ease about taking this step with a new vehicle?
2025 2026 4runner 6th gen Do SR5 wheels fit 33" tire (i.e. 285/70R17) or what's largest size? Do 2025 TRD Pro wheels fit without modifications? 1741639889823-2c
wrydere
Wil
Santa Ynez, CA
Shopping for Tacoma
Those pics just convinced me to go with an SR5 instead of a TRD Offroad - thanks!
theo
theo
Blk4runner1960
I been running tire 2” taller for 6 years. If you going 55mph you really doing 57mph. How many of yall run over the speed limit anyway?. If you miss goodie good driver just drive 2 mph under the speed limit
KTRAN
Kevin
Bay Area CA
4R
285/70/17 tires (Nitto Terra Grappler) on stock SR5 wheels - no rubbing at all. This one's not mine but thought it'd be helpful to share here.
2025 2026 4runner 6th gen Do SR5 wheels fit 33" tire (i.e. 285/70R17) or what's largest size? Do 2025 TRD Pro wheels fit without modifications? 285:70:17 Nitto Terra Grapller Tires SR5 2025 4Runner 6th gen
And here's another 285/70R17 installed on factory SR5 wheels:
2025 2026 4runner 6th gen Do SR5 wheels fit 33" tire (i.e. 285/70R17) or what's largest size? Do 2025 TRD Pro wheels fit without modifications? 285:70:17 Nitto Terra Grapller Tires SR5 2025 Toyota 4Runner 6th gen
Shawnishhere
Shawn
NJ
2025 Toyota 4Runner SR5
Has anyone put on the 18 inch rims/33 inch tires from the 2025 TRD Pro on a regular SR5 with no modifications?
JR1
Joe
Missouri
I’m getting ready to install 2025 TRD Pro wheels on my Sport premium. I’m going with a 265/65/r18 Mickey Thompson Baja Boss AT. These tires are available in a SL. I don’t want an LT tire. Two dealerships told me that the wheels will fit. Everything is the same. Bolt pattern, hub bore. The wheel is a little wider than stock.
