JenningsESQ
Jon
2020 Tacoma TRD OR Premium
Anyone know the specs of the onboard air compressor in the 6th gen Trailhunter 4Runner? Is it an ARB Air Compressor? The Tacoma Trailhunter has lots of ARB parts on it already, so would actually be surprised if this wasn't ARB Air.
This is the best pic I've seen of it (from Motortrend) and we can at least see its function buttons:
2025 2026 4runner 6th gen Onboard Air Compressor in Trailhunter 4Runner -- Specs? ARB Air Compressor? 6th gen onboard air compressor 2025 4runner 6th gen
Functions:
Power, Preset, Menu, Start / Stop, Up / Down
There's also an NPT air compressor hose hookup, 12V DC power outlet, USB-C port.
I think the onboard air compressor will be one of the most desired retrofits installs (on the other trims). Question is how much it'll cost and what work will be involved. It'll be interesting to see exactly where they placed the compressor unit, which will determine how much work and money is involved to install it.
Jack
Jack
SLC, UT
FJ
Love this. This is one of the biggest draws of the Trailhunter 4runner trim IMO.
If it was ARB, they probably would have mentioned it in the marketing and press release tho? It would have brought even more attention and cachet to the onboard air compressor.
Gastan
Tacoma TRD Pro
If it's ARB, let's hope it's the ARB twin motor compressor with full duty cycle and not the single
andim
Boston
2015 Cherokee Trailhawk
I'm a bit conflicted on that one. It's neat and tidy to have it built in. However, if it breaks then you need to go to the dealership to get it fixed under warranty.
I actually prefer to have a separate compressor that I only bring if necessary. No need to drive around a compressor for weeks on a daily commute just to have it on the occasional weekend where you can go wheeling. They are relatively cheap and easy to replace.
Also, for the built in compressor you need to always have the long hoses in the car. A separate compressor can be carried from tire to tire.
I assumed most people in the market for an off road focussed truck already own air compressors and would not want to pay for a built in option. Often these car manufacturers options are twice as expensive as similar aftermarket gadgets.
Scott2373
Most name brand stuff has their logo on it. I don't see any brand markings on this, but then again, it's pre-production so that's subject to change. Maybe it's a Viair, so it's not labeled as to not interfere with the ARB collab.
A compressor is one of those things that I never leave home without. I've been carrying a portable one under my back seat, for years now. This is a handy item to have, but at the same time, if the price is over-"inflated", then there's no way I'm going to finance an option like this, when I've already got one.
JenningsESQ
JenningsESQ
Jon
Good point about the lack of any ARB logo. And I'm with you on never leaving home without an air compressor. If this Trailhunter onboard compressor turns out to be well specced and reliable, it'll go far in helping sell the Trailhunter model IMO
TEAMSLO
NV
Bronco WT / JLURD
we are talking about the trailhunter trim here..... There are those of us that have more focused rigs for the dirt that require not just being an onboard but 100% duty cycle as well. Specifically for myself, have a couple of rigs where the onboard is built into a cargo area out of the way, all that is needed to be done is opening the rear gate and hooking up a 4 hose system and let it do its thing.
Other times we have to air up others when their systems take a dump or a newbie needs to air up. No opening of a hood, no carrying around a hot compressor down in the dirt tire to tire especially at the end of a long exhausting day.
And then there are air lockers n other uses.
I'm assuming this will be a single which may or may not do much good with my plans. However, if it does come as a twin, that would be a bonus for sure.
Moore_Coop
Cooper
Florida
2014 Jeep Wrangler Rubicon
2025 2026 4runner 6th gen Onboard Air Compressor in Trailhunter 4Runner -- Specs? ARB Air Compressor? IMG_6876
If you zoom in just above the “start/stop” button it appears the brand is NSV
zachavm
Zach
Subaru Forester and Ascent
zachavm
Zach
So looking at pictures of the prototype interiors, the 4Runner definitely will not be able to install the compressor as an accessory. For the Tacoma there is a DC/USB power supply in the slot the air compressor occupies on non-trailhunter trims. The 4Runner has a specifically designed interior for it. One could probably make it happen with enough work, but it would not be a small task.
Here is the trailhunter and limited rear cargo areas:
2025 2026 4runner 6th gen Onboard Air Compressor in Trailhunter 4Runner -- Specs? ARB Air Compressor? 1716230913295-m3
2025 2026 4runner 6th gen Onboard Air Compressor in Trailhunter 4Runner -- Specs? ARB Air Compressor? 1716230957761-5q
Scott2373
olefriend
TX
Here's another look at the onboard air compressor in the Trailhunter 4Runner
Cory39744
Cory
Virginia, USA
Reviving this thread. Has anyone been able to get the part number for the 4Runner Trailhunter onboard air compressor yet? I popped the top cap off the wheel well of my Pro yesterday and it has the power connector for it. It seems pretty plug and place other than cutting out the spot in the plastic to fit the display and bezel.
spike-1999
Wauconda, Illinois
‘23 Tacomo OR
From what the dealer told me, there are three part numbers. One for the air compressor, one for the bracket, and one for the hose kit. Here are the part numbers given to me, and Toyota’s site confirmed they fit the 4Runeer TRD Pro.
Note,, unlike the Tacoma part number, these end with -AB, -AC, and -AD
2025 2026 4runner 6th gen Onboard Air Compressor in Trailhunter 4Runner -- Specs? ARB Air Compressor? IMG_6066
