rgall927
Ryan
Charleston, SC
2026 Toyota 4Runner SR5 - Underground
I figured someone might be looking for this kind of comparison photo between a stock SR5 and a lightly modified SR5 with some of the typical upgrades.
Right is a stock SR5
Left is an SR5 with 33" tires (285/70R17) & a Westcott Preload Collar Lift kit
2025 2026 4runner 6th gen SR5 with 33s & Westcott Preload Collar Lift vs. Stock SR5 IMG_8607
2025 2026 4runner 6th gen SR5 with 33s & Westcott Preload Collar Lift vs. Stock SR5 IMG_8606
ThatSickRIp
TSR
VA
2026 4Runner SR5
Im definitely one of those someones, this is EXACTLY what Ive been looking for and the timing is crazy.
Ive got my 285/70s going on this weekend and I was planning on getting the WD lo pro rack. I was also looking at the WD pre load kit for after, but its all pending on how the 2 previous mods affect the 4R fitting in my abnormal garage.
I currently have roughly 2.5" of clearance in my garage for the shark fin antenna. The 285s should add 1.1" and the WD lo pro is lower than the antenna, so those 2 should be good.
If they are, I was planning on a small level for the front.
Are you using the full WD kit on yours? collar and spacer up front, puck in the back?
Really appreciate the post, the timing is unreal and exactly what Im looking for as we speak 🍻
rgall927
rgall927
Ryan
Charleston, SC
Are you using the full WD kit on yours? collar and space up front, puck in the back?
That’s crazy! I knew someone would be looking for this.
Yes I’m running the full kit - collar and spacer up front and puck in the back. Glad this helped you out!
nofriends
NoFriends
texas
2025 Toyota 4Runner SR5 4wd
What parts did you use for the lift? And factory wheels or after market?
JM92
Josh
Charlotte NC
2026 4Runner TRD Offroad Premium i-Force Max
I also have installed the Westcott design 2.5 front .75 rear preload collar kit to my 2026 ORP and added Mickey Thompson Baja boss 285’s
2025 2026 4runner 6th gen SR5 with 33s & Westcott Preload Collar Lift vs. Stock SR5 IMG_8830
2025 2026 4runner 6th gen SR5 with 33s & Westcott Preload Collar Lift vs. Stock SR5 IMG_8834
rgall927
rgall927
Ryan
Charleston, SC
Looks awesome! Bronze wheels look great on Everest
PC4runner2
Doug
Utah
6th gen
Looks great. The grille part number says it doesn't fit an sr5. I just wanted to double check it fits before I buy it. And how hard was it to put on?
Thanks
