Low profile roof rack for SR5
ThatSickRIp
TSR
VA
2026 4Runner SR5
Picked up my SR5 Saturday, and been working on a list of what Im going to do to it.
I really want a roof rack for family trips, but my garage is super short. I dont have a height measurement yet (need to get it, never worried about it since my F150 is definitely not fitting)
Ive got a few Im currently looking at, and the Rhino Rack Reconn is my favorite visually, but I wanted to see if there were some brands that were really low profile or racks thats are known to be low profile.
Ill measure the garage tonight to help with the recommendations.
VG EDC
Vince
Calgary Alberta Canada
2025 TRD ORP Hybrid
I have the Prinsu Pro rack, it's pretty low profile. I also have a 7' garage door. I fit mine in with a Rooftop tent (Go Overland Canada Summit Lite about 4.875" thick), the rack, and slightly larger tires (275/70R18r). I still have about 4-5" to play with IIRC
ThatSickRIp
TSR
VA
2026 4Runner SR5
Awesome, thanks!
I honestly need to be able to fit the Old Ladys 25 LC in there vs the 4R, but the 4R is smaller so it might be a good excuse as to why it gets to be in the garage 😅
mfoga
r4unner
Wescott lo profile is lowest you can find. I did lot of research. It is actually lower than the factory side rails.
The rest of them Prinsu, Victory 4x4, Sherpa are all about the same height.
ThatSickRIp
TSR
VA
2026 4Runner SR5
Good to know, thanks!
Do you have the Wescott? If so, how is it?
Furrypanda1121
2025 4Rrunner
I have the westcott lo-pro. I love it. Less wind noise than the standard cross bars, easy to install. Doesn't rattle once everything is tightened down. And it has a built-in bottle opener for when you get to your destination.
ThatSickRIp
TSR
VA
2026 4Runner SR5
2025 2026 4runner 6th gen Low profile roof rack for SR5 {filename}
Any preferred vendors to look at?
ThatSickRIp
TSR
VA
2026 4Runner SR5
Garage heights:
75" to weather strip
76" to frame
So not much to work with unfortunately
mfoga
r4unner
No complaints. They all use very similar technique. The Prinsu pro had stronger cross bars, Sherpa doesn't require silicon sealant. They may use different AL for side rails or different thickness but not seen a lot on that spec but they are all pretty much the same just slight variation on height. I was concerned about height as I was adding a RTT that is stored up against the ceiling of the garage.
rockymtncole
Cole
Ohio
25 Heritage Blue Limited
I just installed the Westcott Lo Pro and like it a lot. High quality all around. As someone else stated, its no taller than the factory rack. Definitely quieter than the factory rack, which I did not expect since there are so many cross bars.
2025 2026 4runner 6th gen Low profile roof rack for SR5 IMG_1678
2025 2026 4runner 6th gen Low profile roof rack for SR5 IMG_1679
2025 2026 4runner 6th gen Low profile roof rack for SR5 IMG_1677
ThatSickRIp
TSR
VA
2026 4Runner SR5
Awesome info and pics, thank you!
