- First Name
- Rich
- Joined
- Jun 26, 2025
- Threads
- 7
- Messages
- 111
- Reaction score
- 47
- Location
- Portland, OR
- Vehicle(s)
- 2025 4Runner TRD Off-Road
Love the detailed write up! Thank you so much! You didn't happen to take any pictures? I won't ask you to dismantle the whole batch to help me out, but again thank you a bunch! I'll see if I can replicate it.I don't have a power lift gate either. SR5.
It is possible to run the wires through the large boot, then down the drivers side. There is a large black plastic cover to remove to access that area. No tricks to that just unscrew & remove. I used that big zip tie to help pull the wire through the area you can't reach. Inside the gate I taped the new wire to an existing harness at several points along the way from the boot down the driver side (well as far as I could reach through the opening) to keep it clear of the widow when it retracts. I actuated the window to verify before closing it all back up. The wire can feed from the drivers side over to the middle of the door safely by going right along that other existing harness.
To get the boot apart first just pull the rubber away where it meets the body. It doesn't extend into the body, it's just held by a plastic retainer ring on the inside. You can just pull it off. Then there is a white plastic retainer oval ring left behind in the hole. It's just held in by 4 clips that you can work loose with a spudger. The boot and the retaining ring stays on the bundle, don't bother trying to disassemble the ring evennthough it looks like it comes apart. Just work the rubber back onto the ring, and then later it just snaps back into the hole
Only real problem is you can't get through the flex boot at the hinge on the vehicle side without damage. The boot has a membrane that is tightly strapped around the wire bundle and seals from the bundle to the outer shell. You cannot insert *anything* new into the middle with the wires. I even tried greasing up a big zip tie with conduit pull lube and poking it down the middle. Not a chance.
You have to pierce the membrane. The area is inside the body so it should never be wet there in theory but you know with automotive there is no such thing as too much sealing or too many layers of barrier. That membrane is there for a reason.
Power (in my case) comes from the plug for the optional extra cargo lights in the pillar next to the jack storage. I have those lights but the plug is there whether you have the lights or not. The wire goes up the pillar and over to the boot pretty easy. You have to pull a few plastic retainer buttons from the head liner and pull it down a little.
The wire was the perfect length for all this routed this way, incluing enough slack at the bends so it isn't being pulled at any time.
