TRD Pro Wheels - 275/70 tire without lift?
stansmith7777
Utah
Thinking of getting the TRD pro wheels with +20 offset for my SR5. Can I run 275/70r18 without rubbing on stock suspension with NO lift. All the answers I’m finding include a lift.
BonRunner
2026 TRD Sport Premium / WCP
Yes, they'll fit. I have them on now, Falken Wildpeaks AT4W. Front mud flaps will rub, so remove them. No lift.
I have on Pro trim mud flaps. They are slimmer & wider. No rub!
2025 2026 4runner 6th gen TRD Pro Wheels - 275/70 tire without lift? 4runner new tires_1(1)
2025 2026 4runner 6th gen TRD Pro Wheels - 275/70 tire without lift? 20260605_181621
2025 2026 4runner 6th gen TRD Pro Wheels - 275/70 tire without lift? 20260605_181609
2025 2026 4runner 6th gen TRD Pro Wheels - 275/70 tire without lift? 20260605_181552
2025 2026 4runner 6th gen TRD Pro Wheels - 275/70 tire without lift? 20260605_181512
2025 2026 4runner 6th gen TRD Pro Wheels - 275/70 tire without lift? 20260605_181443
stansmith7777
stansmith7777
Utah
Thanks! How’s the articulation of the front suspension and wheels when you off road? Does they hit the body?
Joe Dirt
Hello, I like your mud flaps you mentioned you have the pro trim mud flaps? I was told they will stick out. I have not seen them in person but yours seem to cover the offset difference for the front and rear wheel. Are those Factory oe Pro mud flaps? Thanks in advance
BonRunner
As I said, I have the Pro mud flaps. You buy them from Toyota. They come stock on Pro/Trailhunter trim. All other trims have standard flaps. They are wider & slimmer. They won't rub your big tires (I have 275/70/18; 33.5" tires). The rub is mainly on the front set. Rear doesn't rub. Stock flaps looks smaller too. Pro flaps have wider coverage. See pics below:
2025 2026 4runner 6th gen TRD Pro Wheels - 275/70 tire without lift? 20260604_182206
2025 2026 4runner 6th gen TRD Pro Wheels - 275/70 tire without lift? 20260604_184042
2025 2026 4runner 6th gen TRD Pro Wheels - 275/70 tire without lift? 20260604_185942
Joe Dirt
Hey thanks for the pics. They look pretty good. I'm still on the fence weather to go with some other brands that are pretty popular. I don't really get that much weather here in SoCal but mostly in winter when I go up into the mountains. Thanks
BonRunner
The reason I went with Pro flaps because it has the "4RUNNER" letters on the rear. Also, they were half off.
If you want to save money, get a similar wide one on Amazon for under $50: https://amzn.to/4xdKV1s
Joe Dirt
Thanks for that bit of info. Yes the unbranded might be the way to go as a temporary mud flap for winter use.
